8mm spacers
Old Sep 9, 2006 | 03:28 PM
baltos's Avatar
baltos
Default 8mm spacers
has anyone put 8mm spacers on there stock studs ,if so have you had any problems? i was thinking about doing this but wanted to check with you guys first! thanks in advance
Old Sep 9, 2006 | 04:44 PM
1nate7's Avatar
1nate7
I think 8mm is too big for the stock studs. I am using 5mm to clear my BBK, and even that is pushing it. The lugs only have about 4-5 full turns on them.
Old Sep 9, 2006 | 04:52 PM
baltos's Avatar
baltos
so i guess 8 mm is out !thanks for the info
Old Sep 10, 2006 | 05:51 AM
2 low Z's Avatar
2 low Z
I tried HR 5 mm on stock studs and it was just under the required turns. I'm sure 8mm won't work. As a rule of thumb, you should measure the thickness of the stud and be able to "turn" down on the stud the same length.
Old Sep 10, 2006 | 07:19 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yeah 8mm is too much for stock studs
Old Sep 11, 2006 | 12:37 AM
Sholmes555's Avatar
Sholmes555
question...are you guys talking about wheel spacers or something else? i'm a noob so when you guys said that 8mm might be too much for stock everything, that got me a bit worried cuz i was thinking to buy 25rear, 15-20front (assuming i can find a good deal).
Old Sep 11, 2006 | 02:02 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by Sholmes555
question...are you guys talking about wheel spacers...?
look at the title of the thread.
Old Sep 11, 2006 | 10:17 PM
Triple8Sol's Avatar
Triple8Sol
I think 5mm is really the max you should be doing w/stock studs
FromGtoZ
Sep 20, 2015 03:41 PM
torchkc
Sep 11, 2015 08:26 PM
