Need advice on offset
Old Sep 14, 2006 | 03:29 PM
chris'smax's Avatar
chris'smax
Default Need advice on offset
Ok guys another will this rub thread.
I have a brand new set of volk gt-n's with Kumho ASX tires sitting in my garage right now. The tire sizes are 245/40/18 and 275/35/18. Now the problem is the rears are 18x10 with a offsett of 18mm so i am not sure i can get away w/ this with out rubbing. I have searched this topic but it seems everyone i have seen running this setup is running a 285 width tire. Also i am going to be running Tanabe gf210 springs.
I know i can roll the fenders but since i just bought this car a week ago and would like to avoid messing the car up. So can i run these wheels in the rear w/ tanabe springs with out rolling the fenders or using a crazy a$$ negative camber.
Thanks
Chris
Old Sep 14, 2006 | 04:04 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
18x10 +18 is going to be very close with a 285 tire. My guess is it will rub especially after you get your alignment.
You might consider getting 275.
Old Sep 14, 2006 | 04:08 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
275/40/18. Very nice wheels BTW.
Old Sep 14, 2006 | 04:09 PM
chris'smax's Avatar
chris'smax
They already have 275's on them.
Old Sep 14, 2006 | 04:21 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Oh I thought you were considering getting 285, I misread.
Old Sep 14, 2006 | 04:23 PM
chris'smax's Avatar
chris'smax
Its cool. So do you think that wheel/tire setup will clear with the tanabe springs?
Old Sep 14, 2006 | 09:27 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Eh, probably will clear, but make sure you're at least sort of OK with rolling the fenders.
Here's what you should do:
google for "wheel offset calculator"
use wheel offset calculator and enter these specs : width 10.5" +23 offset
now compare to your 10" wheel with +18 . It will say the new wheel retracts in by 1mm.
Mine just barely rubbed (hotchkis springs), with a 285 tire. So with a skinnier tire, and 1mm more clearance, I think you should be fine. That is my rationale, take it or leave it.
Old Sep 15, 2006 | 05:25 AM
chris'smax's Avatar
chris'smax
thanks for the advice. I guess i am just going to get the springs and then slap everything on and see what happens. Worst case i will have to roll my fenders which i have had done before so it really isn't THAT big of a deal.
Old Sep 15, 2006 | 05:10 PM
xav_350z's Avatar
xav_350z
guys 275/40-18 rear with 10.5 18' +28 +tannabe gf210 will work fine
Old Sep 15, 2006 | 10:51 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I believe so, yes.
liqalu04
Jan 2, 2022 12:58 PM
seagrasser
Oct 11, 2015 03:27 PM
