TPS sensor
Old Sep 27, 2006 | 09:01 AM
HKhan's Avatar
HKhan
Default TPS sensor
I want to buy some Work S1's but i dont want to comprimise the integrity of my electronics. what can i expect by changing my stock wheels? Ive heard warning lights go off and beeps but what can i do to prevent that. Or do i have to buy new TPS sensors from the dealer for my new tires. Also cant i reuse the sensors from the stock tires? any suggestions would be great. please help. thanx!
Old Sep 27, 2006 | 09:42 AM
THE TECH's Avatar
THE TECH
I have the S1's and the dealer could not reprogam them to work. My previous set of Works had zero issues, so I'm not sure what the deal is with these. I banded the sensors on both sets of wheels since the stock TPS will not fit in the S1's.
Old Sep 27, 2006 | 09:58 AM
Luscious Luke's Avatar
Luscious Luke
I just had my stock TPS sensors installed in my new 20 inch Asanti's. I just had them drill another hole to mount them in and they work beautifully. No lights or beeps, and they read the right tire pressure. You can have them drill a hole in the inside of the wheel behind a spoke, you wont even see them. Piece of cake.
Old Sep 27, 2006 | 10:47 AM
buffmanjeff's Avatar
buffmanjeff
Ha, you've got some *****. I would never drill into my rims 1. they lose their value and 2. what if they f up, then you going to wait another 3 months to get another wheel from volk. There HAS to be another way around this, and i know alot of people use the TPS in aftermarket wheels on here.
Old Sep 27, 2006 | 10:49 AM
THE TECH's Avatar
THE TECH
^ Agreed. Doesn't sound like the best idea. If the hole is at all incorrectly drilled, you could end up with a constant air leak. Plus, what do you do if you ever want to sell them??
Old Sep 27, 2006 | 11:32 AM
Luscious Luke
It works out well when you have a top notch, high end wheel shop take care of this for you. And if they F it up, they buy you a new one and have it expedited from the manufacturer, no sweat off your sack. There is another way around it, strap it to the inside of the wheel with a wheel band strap. Just hope it doesnt come off and start bouncing around inside your wheel.
Old Sep 27, 2006 | 11:33 AM
Luscious Luke
If you end up wanting to sell them, you just pull them out and replace them with rubber valve stems, simple.
Old Sep 27, 2006 | 11:36 AM
Luscious Luke
Call me crazy, but when you have a 2500 dollar tire pressure monitoring system built in stock to your brand new Z, it would be nice to use it. Just my opinion and reasoning behind keeping my TPS system working, but you guys can take it for a grain of salt.
Yes, I am crazy, but atleast I know when I need air. LOL
Old Oct 3, 2006 | 08:08 AM
THE TECH's Avatar
THE TECH
Just an update for anyone who is interested. Your stock TPS will work with aftermarket wheels. I have now used my original sensors on two sets of aftermarket wheels using the banding method and they work fine.
Now as far as Performance Nissan telling me that they wouldn't work cause the wheels were too big has now been debunked. Now, if you plan to use sensors other than your original stock ones, I cannot say whether there will be issues or not since Performance couldn't read the ones that I brought them. I speculate that it was lack of knowledge at the dealership. That is just a guess though.
Old Oct 3, 2006 | 08:10 AM
norapat01's Avatar
norapat01
What's the banding method? could you please explain to me, so i could i finally get some aftermaket wheels.
Old Oct 3, 2006 | 08:22 AM
THE TECH's Avatar
THE TECH
It involves steel bands to hold the tps to the wheel. There are a couple of sticky threads about it in the wheel section.
Old Oct 3, 2006 | 09:17 AM
norapat01's Avatar
norapat01
Links?
Old Oct 3, 2006 | 09:30 AM
THE TECH's Avatar
THE TECH
Originally Posted by norapat01
Links?
Don't be lazy bro. It is at the top of the wheels/tires section.
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
