Running 2 Different Tires Bad/Good?
Old Oct 16, 2006 | 09:49 AM
Jorge Cabrone's Avatar
Jorge Cabrone
Default Running 2 Different Tires Bad/Good?
Hi All,
I spoke with a shop and they do not recommend running 2 different brands of tires? Anyone running two different brands of tires with any problems? If so, what type of problems do u run into?
Old Oct 16, 2006 | 10:09 AM
bailey bill's Avatar
bailey bill
As long as you have matched pairs on the front, and matched pairs on the rear, it won't make any difference.
bill
Old Oct 16, 2006 | 10:17 AM
Mixing different brands of tires is neither good nor bad. Handling is unpredictable.
Old Oct 16, 2006 | 10:21 AM
dubbzdiggler's Avatar
dubbzdiggler
it's not ideal, but people do it. It can make the car less predictable espeically if you have say two Z rated on the front and two H or V on the back...even W and Y, but less noticeable. Where you'll really notice unpredictable handling when mixing is when you do two snows and two regular performance tires..that's why it's always best two run four snows. You should always run of the same tires. It's like wearing two different shoes...it doesn't make sense and they both perform differently.
dubbzdiggler
Good call davidv
Old Oct 16, 2006 | 10:43 AM
Jorge Cabrone
Thanks All for your input. I purchased a front set of Bridgestones (for new 19"rims) since they were dirt cheap on Tirerack and was going to go with Nitto's since I would have gotten a good deal on those. But I will move forward with buying Bridgestones for the rear set.
Old Oct 16, 2006 | 10:48 AM
Jyoder7's Avatar
Jyoder7
bill
Wrong. If your tires in the rear have less grip than the ones in the front you're going to have some handling issues at the limit and vice versa.
Old Oct 16, 2006 | 03:30 PM
iceburns288's Avatar
iceburns288
You're going to have handling issues at the limit no matter what. The tires you have just changes where that limit is.
Old Oct 16, 2006 | 04:36 PM
thirty5ounces's Avatar
thirty5ounces
nittos in the rear bridgestones in the front.....i havent hit any walls
Old Oct 30, 2006 | 01:24 PM
kaybee650's Avatar
kaybee650
i have kuhmo mx's in front
i have advan ao48's in the rear
handles like a dream.
Old Oct 30, 2006 | 01:29 PM
jakesford's Avatar
jakesford
yeah since most people will never push their car to limit anyways it won't really matter...
Its the same with people putting the widest tire they can fit in the rear... the Z understeers stock wo lets add more grip to the rear
Old Oct 30, 2006 | 01:44 PM
Eazzy's Avatar
Eazzy
Im a firm believer in BALANCE----Meaning standardizing components. Two fronts with two different rears is a gamble, May be perfect or may throw u into a spin out some night. Im all for experimentation <<<<< understatement ,but tires, like pistons, or brake pads are designed to work as a team
Old Oct 30, 2006 | 07:23 PM
Jyoder7's Avatar
Jyoder7
ditto.
Old Oct 30, 2006 | 07:29 PM
TurboTrey's Avatar
TurboTrey
As long as the tires on the front are the same and the tires on the rear are the same you shouldn't have any problems.
Of course if you put crap tires on the front and good tires on the back you will have poor traction in the front. As long as you have good tires on the front and rear that are matching sets you will be fine.
Drifting or autocrossing is about the only time when I can think of that you must have all 4 matching.
Old Oct 30, 2006 | 07:58 PM
Triple8Sol's Avatar
Triple8Sol
I've run quite a few different front/rear setups. Haven't had any issues since they're different sizes anyways. Not even VDC issues.
Old Oct 31, 2006 | 12:57 AM
Z33Benny's Avatar
Z33Benny
werd to that.
