5MM Spacers...
Old Oct 28, 2006 | 01:06 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
Default 5MM Spacers...
Will they work with Work KIA +20 all around? I know I'll have to roll the fenders. Does any company make 3MM spacers and will I have to get longer studs for either? Thanks.
Old Oct 28, 2006 | 01:25 PM
josephchihweilu's Avatar
josephchihweilu
i dont know if u have to get longer studs, but i know many people running 10mm spacers without longer studs. Project kics and ichiba both make decent spacers from what i hear.
Old Oct 28, 2006 | 01:28 PM
Eazzy's Avatar
Eazzy
Do u relize that 5 mm is like 3/16 of an inch ?
Old Oct 28, 2006 | 06:28 PM
davidf's Avatar
davidf
I've used 5mm with stock lugs, but no more than 5mm recomended with them.
Old Oct 29, 2006 | 07:13 AM
Gsedan35's Avatar
Gsedan35
5mm spacers don't allow you go grap enough theads to get away with using the oem studs, H&R includes longer studs with their 5mm kits for a reason. I had the H&R 5mm kit, speaking first hand.
Old Oct 29, 2006 | 08:00 AM
1nate7's Avatar
1nate7
I use 5mm spacers in the front to clear my BBK and am still using the stock studs without a problem. While I am doing this, I don't really recommend it especially if its just for aesthetic purposes. 3mm would be safer with stock studs if you can find such a thing, but what's the point? 3-5mm won't make much of a difference in looks really.
Old Oct 29, 2006 | 09:31 AM
JETPILOT's Avatar
JETPILOT
My 5mm H&R spacers came with extended lugs. Never use the stock lugs with spacers and Duralumin lug nuts like Rays.
Old Oct 29, 2006 | 10:27 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
what width is your wheel?
Old Oct 30, 2006 | 02:11 PM
MyV6IsFast3r
The thing is I have a +20 offset on a 8.5" Front and 9.5" Rear wheels. They are damn near flush with the fender as is. I dont want to run into any problems, the only thing I want to do is roll the fender and I really dont want to do that if I dont have to, just want to get the weels out there so they look a little better.
Old Oct 31, 2006 | 12:12 PM
solidsnake's Avatar
solidsnake
I would say thats true but only with 10mm or wider.
Old Nov 2, 2006 | 06:05 AM
Rob_Quads's Avatar
Rob_Quads
Rule of thumb is you should be able to make 6 complete turns of the nut. If you can do that you have sufficient amount to be safe
Old Nov 2, 2006 | 06:43 AM
MyV6IsFast3r
Sweet thanks a lot. I think I'll try that. Im still wodering if +15 all around will give me problems.
djParis
Aug 7, 2007 04:20 PM
dutchboy350Z
May 16, 2007 04:50 PM
ares
Mar 9, 2004 01:26 PM
Nocturnal
May 9, 2003 11:13 AM
Audito350Z
May 5, 2003 02:28 AM
