Widest tires on track rim
Old Nov 12, 2006 | 11:37 PM
topnotch350z's Avatar
topnotch350z
Default Widest tires on track rim
I've searched and couldn't find an exact answer.
Can anybody tell me whats the widest I can go on the track model rims? I'm currently running the stock specs of 225-45-18F and 245-45-18R.
Or if I'm just blind and this topic has been covered please redirect me to that thread, thank you.
Old Nov 12, 2006 | 11:40 PM
For safety I recommend OEM width plus 20mm.
Old Nov 13, 2006 | 04:16 AM
lowrider's Avatar
lowrider
Tracks are 8" wide in front and 8.5" wide in the rear (2003-2005). You can run a 245/40/18 in the front and a 265/40/18 in the rear.
Lou
Old Nov 13, 2006 | 04:17 AM
taurran's Avatar
taurran
I know people running 275's on them. 285's should fit but might look funny.
Old Nov 13, 2006 | 04:31 AM
lowrider's Avatar
lowrider
You don't want to do this. See page attached:
http://www.tirerack.com/tires/Spec.j...e1=yes&place=3
Both the 265 and 275 are recommended for a 9" minimum rim width. The 265 is .02" less in cross section, and whould work just fine on an 8.5" wheel. Anything above that is pushing it. You'll have tire bulge, something that is not safe or attractive. Yep, some folks do it, but it's really not safe and a tire shop that would install such a combo is not reptubale. You would also lose any support from the tire manufacture since you're not following his recommendations.
Lou
Old Nov 13, 2006 | 08:41 AM
topnotch350z
Lou
Thanks!
Old Nov 13, 2006 | 02:51 PM
taurran's Avatar
taurran
Lou
I wouldn't call it "not safe". They add those "safe" widths to the chart with a good degree of play to avoid any liablity if something does happen. I agree that its more than you would normally want to do but its definitely possible. People run oversize tires all the time and I've never heard of them rolling off the bead. I personally wouldn't go over a 275.
Old Nov 13, 2006 | 06:09 PM
topnotch350z
so if i run 275 out back i shouldnt have problems right?
Old Nov 16, 2006 | 12:12 PM
Chest Rockwell's Avatar
Chest Rockwell
I'm thinking about doing these widths with PS2's... is this going to look goofy?
Lou
Old Nov 16, 2006 | 02:37 PM
lowrider's Avatar
lowrider
No!
Lou
Old Nov 16, 2006 | 03:30 PM
taurran's Avatar
taurran
I'm just saying its an overside tire but should fit. I'm not going to endorse it by any means because as stated its outside of most tire specs.
Old Nov 16, 2006 | 05:37 PM
lowrider's Avatar
lowrider
It's outside of ALL Tire recommendations
Lou
ablaine
Nov 29, 2016 10:13 AM
