Purchasing new tires
Old Nov 25, 2006 | 09:17 PM
uncutZ00's Avatar
uncutZ00
Default Purchasing new tires
Hi everyone,
I have about 25k miles on my Z. I have changed the rear wheels. THe front wheels are still stock potenzas. The tires on the rear are Toyos4.
After switching out the back tires, I feel that my Z has more body roll on the freeway when switching lanes at higher speeds. This never happened before i switched out the back tires.
Could this be due to the Toyos having softer side walls? Or could the different tread patterns in the front tires and back tires?
Should I just purchase 2 new toyots for the front tires? I really don't want any body roll. Or should I purchase 4 new set of tires? What brand can i get for about $200 per tire?
Old Nov 25, 2006 | 09:18 PM
zand02max's Avatar
zand02max
You should run 4 of the same, ie, buy new fronts as well!
Old Nov 25, 2006 | 09:39 PM
bofa's Avatar
bofa
Originally Posted by uncutZ00
Hi everyone,
You can do much better than 200/tire on ebay and possibly through some of the sponsors. Some people favor discount tire (tires.com) and tirerack.com too. Just figure out what you want and start searching.
But I would suggest getting all 4 tires at this point since you know you want to replace 2 and the fronts have 25K.
Old Nov 25, 2006 | 09:46 PM
uncutZ00's Avatar
uncutZ00
Hi thanks for the advice.
Are the toyos bad tires? Is this causing my body roll? Or is it the fact that i am running diffferent front and rear tires?
Old Nov 25, 2006 | 09:51 PM
Mixing tires gives different results. Not better or worse just different. If you go to 4 of the same tires, the result will be different than it is now.
For unbiased testing and recommendations check Consumer Reports.
Mattg350z
Oct 2, 2015 06:51 AM
350z82
Oct 1, 2015 06:25 PM
