will 275 on the front
Old Dec 12, 2006 | 02:58 PM
Drift_corners's Avatar
Drift_corners
Default will 275 on the front
Will 275 on the front, ruin my steering feel. Can i get away with it, my goal is maximum traction. any opinions would be great.
Old Dec 12, 2006 | 03:36 PM
DavesZ#3's Avatar
DavesZ#3
Are you autocrossing the car? From what I've seen here and other places, 275 and 285 are pretty common setups for people autocrossing their Zs. I'm looking for a set of tires right now to use next year for autocrossing. Probably 265 or 275 Falken RT-615s.
On the street, I'm running 255s and don't notice any problems with the front steering as compared to stock.
Old Dec 12, 2006 | 03:38 PM
Drift_corners
I am autocrossing, and i just got a tire sponsor, so the price of wide tires is not a big deal. sounds good.
Old Dec 12, 2006 | 03:47 PM
whitetrack's Avatar
whitetrack
Who's your tire sponsor? Are you a member of the Cart in CT?
Old Dec 12, 2006 | 05:56 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I'm running 275/35R18 on 9.5 +30 wheels, steering feels fine.
Chris
Old Dec 12, 2006 | 06:10 PM
350Zteve's Avatar
350Zteve
Yep, they will fit fine as long as the wheel offset is right. On a 9.5" wheel, a 27-30mm offset will be good.
Old Dec 12, 2006 | 09:20 PM
mikhe's Avatar
mikhe
running 19x9.5 +22 offset atm. Running 275/30/19 with no issue whatsoever. have about -3 camber in front
Old Dec 12, 2006 | 09:31 PM
Volk350Z's Avatar
Volk350Z
Master
it will work... i have 285/30/18 on my car
Old Dec 13, 2006 | 10:26 AM
World Famous Z's Avatar
World Famous Z
I was running the Nismo LMGT-4 wheels on my car, 18x9.5 +30 all around before. running 275-35-18 front and 275-40-18 rear. no rubbing at all, fronts were as flush as can be.
as for the steering feel, it became a little (but not too much) heavier, but the instant response of the way the car gripped was nice. I never really pushed it to it's limit back then, so i couldn't tell u how it would react on the track, but I liked the way the car handled with such a large tire in the front.
I highly recomend this setup or anything similar.
I know Jason was running his enkei NT03+M rims in a fairly wide width in the front, and i think he even had 295s on the rear....
Old Jan 3, 2007 | 06:59 PM
350Zenophile's Avatar
350Zenophile
Do you guys think an 18x9.5+22 will be ok in the front?
I just ordered this combo and wonder now if I went too aggressive with the offsets since the Nismos are +30 and the Rotas are +28.
thx
Old Jan 3, 2007 | 07:28 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
It can be done. Rick@Status ran a 275/30/19 with a 19x9.5 +22 with a 15mm spacer and -2 degree camber. No rubbing issues.
Old Jan 4, 2007 | 05:08 AM
350Zenophile
I'd rather not have to run a spacer or extreme camber...Should I change my order to +27?
Old Jan 4, 2007 | 12:03 PM
Drift_corners
Yeah i run there, im only 18 but i got aktuning in florida to give me free tires. They see good things.
Old Jan 4, 2007 | 01:04 PM
1nate7's Avatar
1nate7
I would. That will give you the best chance to run the widest tires possible without rubbbing and be able to rotate front/back if you go with same size tires all around.
Old Jan 7, 2007 | 03:32 PM
Redfoot's Avatar
Redfoot
Unless you are planning to track yor car I would not use that size up front. The car will be more sensitive to pulling when driving over uneven pavement. I live in Michigan and the roads are messed up with overweight trucks and poor maintenance. I use 275s all around for the track and I don't get the street (245/275) tires back on for a few days and run on the 275s. It is a bit annoying to be pulled here and there.
Old Jan 7, 2007 | 04:35 PM
HyperSprite
Mad Scientist
Huh, I run my 275s full time and have not had any problems whatsoever. It certainly does not pull or tramline and according to the people who keep track of such things, we have the worst roads in the country.
Chris
Old Jan 7, 2007 | 07:35 PM
sentry65's Avatar
sentry65
the burninator
i thought tramlining had a lot to do with the tire tread design, compound stiffness, and profile thickness
Old Jan 8, 2007 | 07:14 AM
350Zenophile
It does, as well as offset and suspension settings, etc. etc. I'm curious mostly about the opinions of those who have just changed section width MOL.
Originally Posted by tirerack.com
Unfortunately anything that increases a high performance tire's responsiveness also increases its willingness to tramline.
Pretty good article on tirerack on the matter: http://www.tirerack.com/tires/tirete...currentpage=46
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
