How do I set TPS's?
Old Dec 16, 2006 | 02:01 PM
Beaker02's Avatar
Beaker02
Default How do I set TPS's?
Does anyone know how to set a new set of tire pressure sensors? Must this be done by a dealer? Thanks.
Old Dec 16, 2006 | 04:31 PM
Z BOY's Avatar
Z BOY
yes.
Old Dec 16, 2006 | 10:00 PM
dkmura's Avatar
dkmura
General & DIY Moderator
To be more accurate, the Nissan CONSULT unit must be used to help the ECU 'read' the signals for the TPS. Usually, these units are pretty $$, so you go to a dealer to have this done. Takes about ten minutes.
Old Dec 17, 2006 | 10:24 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Must be done by the consolt at the dealer...
Old Dec 18, 2006 | 06:29 AM
sluggoZ's Avatar
sluggoZ
I always thought that if you place the sensor close to the exact previous location on the valve stem...they should work OK.
Old Dec 18, 2006 | 07:22 AM
THE TECH's Avatar
THE TECH
If they are not your stock ones, you will have to take them to the dealer with your car to have them programmed.
Old Dec 18, 2006 | 08:55 AM
Jason@Performance
Performance Nissan
if you put in a new sensor thats where they will go...
they all go in the same spot...
they just have to be programmed...
Old Dec 18, 2006 | 11:07 AM
Beaker02's Avatar
Beaker02
Thanks all.
Old Dec 18, 2006 | 06:18 PM
k3silk's Avatar
k3silk
yup must be done buy the dealer i just did mine today and it didnt cost me a thing.
Old Dec 18, 2006 | 06:48 PM
sluggoZ's Avatar
sluggoZ
Can you give us some insight on how you accomplished that??
I would appreciate it!
