stock studs/10.5" rims ???
Old Dec 23, 2006 | 12:41 PM
Ilov350ZEE's Avatar
Ilov350ZEE
Default stock studs/10.5" rims ???
i put on my friends 19X10.5" rear rims w/ 22 offset, i noticed the rear studs are shorter about 1/2" long or less, is it suppose to be like that when putting wide rims and low offset? We tried to use the stocks bolts it works but not sure if it is safe. Help, what do i need to do??
Old Dec 23, 2006 | 03:11 PM
supra crazy's Avatar
supra crazy
I don't think the rim width has anything to do with the studs being too short. I think its just the deisgn of the rim.
Old Dec 23, 2006 | 03:41 PM
Ilov350ZEE's Avatar
Ilov350ZEE
but on stock 06 18's its longer than the 10.5" rims on
Old Dec 24, 2006 | 07:35 AM
03Z33's Avatar
03Z33
The low offset wheel just has a thicker "pad" which covers more of the stud. The correct way to measure if you have enough thread engagement is to count at least 7 full turns on the nut before it gets tight against the wheel. If you have less then 7 turns you should change to longer studs like the Nismo 50 or 60mm ones.
Old Dec 24, 2006 | 12:47 PM
Ilov350ZEE's Avatar
Ilov350ZEE
a lot of people here have 10.5" rear w/ 22 offset i wonder if they change their stock studs or still on stock. I just want to know if im safe.
Old Dec 24, 2006 | 12:56 PM
03Z33's Avatar
03Z33
You should be fine. Just count turns if you're worried. It's easy
Old Dec 24, 2006 | 01:12 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I'm on stockers, no problems yet
Old Dec 26, 2006 | 01:25 PM
Ilov350ZEE's Avatar
Ilov350ZEE
i just checked it i have 8 turns, thats good right??
Old Dec 26, 2006 | 06:46 PM
03Z33's Avatar
03Z33
That's Good More then enough.
Old Dec 28, 2006 | 01:53 PM
Ilov350ZEE's Avatar
Ilov350ZEE
cool thanx
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
