10MM wheel spacers are here!
Old Jan 4, 2007 | 02:56 PM
ichibausa's Avatar
ichibausa
Thumbs up 10MM wheel spacers are here!
hey guys, finally the 10mm hubcentric wheel spacers are here! sorry we took so long for new development, but we have to make sure everything going right on to your OE hub. 10mm will work as same as the 15MM and 20MM which studs swap required. Hope this can solve your wheel problems
https://my350z.com/forum/showthread.php?t=240780
Old Jan 4, 2007 | 04:06 PM
keith N's Avatar
keith N
PM sent.
Old Jan 4, 2007 | 04:12 PM
Triple8Sol's Avatar
Triple8Sol
Just curious what makes these better than the H&R and Eibach models that are already on the market? They have the same pricing, are hubcentric, include longer studs, are huge reputable companies, etc...
Old Jan 5, 2007 | 10:18 AM
Rob_Quads's Avatar
Rob_Quads
I sent an enquiry to you about the studs that come with your spaces but I have had no reply - Did you get it??
Old Jan 5, 2007 | 10:35 AM
ichibausa's Avatar
ichibausa
I didn't get that. Please PM me if you need studs, I will get back to you asap.
Old Jan 5, 2007 | 11:14 AM
sam30540's Avatar
sam30540
Im curious why they are better too
Old Jan 5, 2007 | 11:19 AM
ichibausa's Avatar
ichibausa
we didn't say we are better at the first thread post
we just said 10MM is the new item available now.
Old Jan 5, 2007 | 11:20 AM
ichibausa's Avatar
ichibausa
We do have better pricing and we have good inventory for customers. No one would say their products are best in the world but at least we will have good customer service and you don't have to wait to get your items.
You can find some good reviews from here!
https://my350z.com/forum/showthread....ghlight=ichiba
Old Jan 5, 2007 | 11:23 AM
NoLimit's Avatar
NoLimit
BECAUSE Ichiba USA comes on THESE boards to help meet the needs we are asking for!!! To support their product, and make sure you get your order fast!! THAT"S WHY!
Old Jan 5, 2007 | 11:56 AM
sam30540's Avatar
sam30540
I already have 15mm spacers up front and am thinking about switching those to the rear and running a 20 up front. Could i do this without having to switch out the extended lugs on the front or the studs that came with the 20mm? Meaning can i just put the 20mm studs in the rear and put the 15mm spacers back there? Let me know i may be ordering some from you soon
Old Jan 5, 2007 | 01:17 PM
ichibausa's Avatar
ichibausa
15MM using 45MM studs & 20MM using 50MM studs.
If you switch 20MM to the front, your 15MM studs are 5MM shorter which is not safe.
Old Jan 6, 2007 | 06:57 AM
sam30540's Avatar
sam30540
That really sucks. It wasn't that hard to install them just a pain in the *** to get the bolts loose with hand tools. Are your 5mm spacers hubcentric?
Old Jan 6, 2007 | 09:51 AM
ichibausa's Avatar
ichibausa
yes.
Bolt Pattern: 5/114.3
Center Bore: 66.2
Old Mar 13, 2007 | 12:59 PM
RKnight's Avatar
RKnight
Do the splines of the new studs match right up to the splines inside the holes on the hubs that were made from the original installation of the OEM studs?
Also how much extra stress do spacers put on the wheel bearings?
Old Mar 13, 2007 | 02:34 PM
ichibausa's Avatar
ichibausa
the size is same as oe and it's just longer than oe.
Obadabot
Jun 18, 2023 11:31 PM
