G35 TPMS on 350z?
Old Feb 5, 2007 | 10:36 PM
krazi3m3's Avatar
krazi3m3
Default G35 TPMS on 350z?
Well I'm getting 4 tpms from a friends g35 that I'm going to put on my 350z's after market wheels...my question is will nissan be able to recalibrate this fine since the tpms might be different from a factory Z vs a G..
Old Feb 6, 2007 | 04:08 AM
DavesZ#3's Avatar
DavesZ#3
They're all the same. You can use the G's sensors on the Z.
Old Feb 6, 2007 | 07:08 AM
THE TECH's Avatar
THE TECH
^What he said.
Old Feb 6, 2007 | 11:48 AM
krazi3m3's Avatar
krazi3m3
Alrite thanks for the help
Old Jan 12, 2012 | 10:12 PM
(ZzzzzZ)'s Avatar
(ZzzzzZ)
Default Tpms help!!
Hey guys,
So I might be purchasing used wheels. They come with tpms, but the tpms are from a g35. Would they still work on my z? Also, just curious, are all tpms interchangeable?
Old Jan 13, 2012 | 12:23 AM
terrasmak's Avatar
Yes they will work, yes they will need to get programmed to your car to work, and NO, not all TPMS is the same.
Old Jan 13, 2012 | 02:01 PM
(ZzzzzZ)'s Avatar
(ZzzzzZ)
oh so they won't just start working after I drive for a few miles? I have my stock tpms from my z, but thought these would just work. Thanks
Old Apr 6, 2013 | 05:07 PM
dmemenza's Avatar
dmemenza
I know this thread is a little old, but am hoping someone will see this and maybe help with a couple of my questions. I have a 06 G35 coupe. It looks like one or more of my TPMS sensors have gone bad. Does anyone know how much the dealership charges to identify which have gone bad and to reprogram a replacement TPMS sensor for your car?
On another note, it looks like the TPMS sensors labeled 40700-CD001 work for all 350Z/G35 models. Mine is a 06.
Thanks in advance for anyone's help!
- DM
Last edited by dmemenza; Apr 6, 2013 at 05:08 PM. Reason: added car year make model
Old Apr 6, 2013 | 07:52 PM
JDMStanced's Avatar
JDMStanced
After you buy the used TPMS, do you take them to dealership and have them recalibrate?
Old Apr 8, 2013 | 07:32 AM
dmemenza's Avatar
dmemenza
thats what I understood. If they're from another car, you have to get them reprogrammed at the dealership.
- DM
Old Apr 11, 2013 | 11:21 AM
neal@tirerack's Avatar
neal@tirerack
Vendor - Former Vendor
OP, what specific year/model G and year/model 350?
Old Apr 11, 2013 | 12:00 PM
dmemenza's Avatar
dmemenza
Originally Posted by neal@tirerack
What specific year/model G and year/model 350?
2006 G35 coupe, sport package.
Thanks!
- DM
Old Apr 11, 2013 | 03:49 PM
neal@tirerack
If I compare an 06 G and 06 350Z they are the same. I need your specific model year to make sure in your case.
Old Apr 11, 2013 | 06:42 PM
dmemenza's Avatar
dmemenza
If the question was directed at me, I'm not sure what other information you require. I know you're trying to help and I appreciate it. What specific model year are you referring to? I have an 06 G35 coupe, OB color, sport package. Is there something in particular you are looking for?
Thanks,
- DM
Old Apr 11, 2013 | 10:59 PM
JDMStanced's Avatar
JDMStanced
i also need to grab TPMS for 06 g35 coupe. But not sure which side has gone bad..
Old Apr 12, 2013 | 02:27 AM
jomamahama's Avatar
jomamahama
TPMS sensors are consummables like an air filter nowadays. I hate the darn things and just check pressure monthly with the old gauge. Plus with sudden blowouts they don't help you, and with slow leaks you should be able to tell the car is dragging.
Old Apr 12, 2013 | 02:33 AM
JDMStanced's Avatar
JDMStanced
on g35, the tpms light comes on if one of the tpms is bad.
Any way to keep the light off?
Old Apr 12, 2013 | 10:35 AM
neal@tirerack
Thanks,
- DM
Sorry for the confusion. Question was directed to the op.
Old Apr 12, 2013 | 11:15 AM
DavesZ#3's Avatar
DavesZ#3
Huh? Consummable? Hardly, they are a PITA to replace but fortunately they last 7-10 years or more in some cases.
Slow leaks are the very reason that TMPS exist and are now required. With modern radial tires, it impossible to visually tell that a tire is low. Running on underpressured tires is the case of the vast majority of blowouts. The change in handling and the "car is dragging" feeling is so subtle from a slow leak, you'd never notice it. TPMS warns you when you're 25% below the rated inflation pressure, it will detect low pressure long before the majority of drivers would notice.
hulkout
Apr 28, 2017 09:00 PM
Justin100
Nov 29, 2015 03:58 PM
kyin
Oct 15, 2015 05:54 AM
Mattg350z
Oct 2, 2015 06:51 AM
codek
Sep 28, 2015 03:03 AM
