OEM Wheel Modification Thread
Old Oct 15, 2008 | 07:31 PM
  #401
z_roadster's Avatar
z_roadster
does anyone have a link for where to buy some black wheel paint/spray? I'm throwing my stocks on for winter and I think I want to paint them black. I want more of a matte black though, nothing really glossy?
Old Oct 15, 2008 | 08:01 PM
  #402
jubes's Avatar
jubes
just go to auto zone or pep boys they carry wheel paint
Old Oct 15, 2008 | 08:10 PM
  #403
sk26dett's Avatar
sk26dett
I used duplicolor semi-gloss black available at most auto part stores. For the clear coat i used duplicolor matte clear and it turned out pretty good, but if i painted them again i would prefer a little more gloss. I'm not sure what would be the best combo, you have to play around with a combo of gloss/semi-gloss black undercoat and then gloss/matte clear on top and see what gives the shine and finish you want. If i ever paint a set of wheels black again I'm going to try gloss black with a matte clear to tone down the shine. Also, prep the hell out of them before you paint them. Mine never chipped after numerous tire changes and even after i curbed them a little, the paint was solid.
Old Oct 15, 2008 | 08:15 PM
  #404
sk26dett's Avatar
sk26dett
I've had a bad experience with the wheel paint, i used some on an old bicycle and the paint was very brittle, it chipped quickly and didn't stick too well. I prepped the surface properly and i'm pretty good with a spray can so maybe it was the conditions. It is always really humid here. Has anyone else used it?
Old Oct 15, 2008 | 09:29 PM
  #405
z_roadster's Avatar
z_roadster
do you have a picture of your wheels so I can decide whether I want semi-gloss or gloss?
Old Oct 15, 2008 | 10:18 PM
  #406
sk26dett's Avatar
sk26dett
yea, i just posted them on pg. 20
Old Oct 16, 2008 | 03:38 PM
  #407
nothix's Avatar
nothix
I suggest engine enamel at autozone on the cheap.
BTW make sure you get the finish you want with the paint, don't expect to be able to polish the engine enamel, it dont work.
Take your time and do it right otherwise it will look rushed.
Prep work and Finish are key
Old Oct 22, 2008 | 03:56 PM
  #408
KS0385's Avatar
KS0385
Why don't people like white wheels on white cars?
This looks pretty good.
And this looks decent
Old Oct 23, 2008 | 03:24 PM
  #409
cms-35z's Avatar
cms-35z
White wheels on white cars is the sextor.
Old Oct 23, 2008 | 03:59 PM
  #410
autodrifter4's Avatar
autodrifter4
about to buy some stock rims and paint them black for my track rims...will post up when im finished
Old Oct 23, 2008 | 04:29 PM
  #411
jubes's Avatar
jubes
POWDERCOAT = FTW!
Old Oct 24, 2008 | 06:05 AM
  #412
WalkerT's Avatar
WalkerT
Professional
Mine was high temp 500+ low gloss black. Sanded with 400 wet/dry then spraied with rubbing alcohal (removes any grease) and then 5 light coats to make a smooth low gloss finish.
Old Oct 27, 2008 | 12:12 PM
  #413
eyeSea's Avatar
eyeSea
Just did mine a few days ago and wrote up a quick DIY: https://my350z.com/forum/body-interi...tock-rims.html
Old Oct 27, 2008 | 05:03 PM
  #414
03aeroZ's Avatar
03aeroZ
^^very nice looking....did i spy a 6er of coors? was that to prepare you to not turn back? what color did that end up being? that is the type of color i will be going for (dark metallic gray).
Old Oct 27, 2008 | 09:11 PM
  #415
psytropic's Avatar
psytropic
Oh ok.. i'm dropped on S-techs... so you would want the set up i just described... I too am going to get spacers in those settings... hopefully I can find some H&R spacers in those specs.. if not then i'll think about kics or ichiba...
Granted that this is taken on a hill driveway.. you can kind of see the slight gap towards the rear wheel.. which is where you'd want the 25mm to be.
I'm not familiar with using spacers, what would they do? Make the rims stick out more?
I ask because I really like the Rays OEM Track rims and am trying to find some to buy and wanted to know what I would have to do special if my Z is lowered.
Old Oct 28, 2008 | 05:16 AM
  #416
Thermal1's Avatar
Thermal1
spacers push the wheel out closer to the fender. It is just for looks.
Lower the car first, let the springs settle, get an alignment, then if your wheels look sunken, take a ruler and measure how much you want the wheels to move outwards (in mm). Then buy that size spacer. I have those rays track wheels and I am lowered. I will be grabbing some 20-25mm spacers whenever I get around to it.
Old Oct 29, 2008 | 08:11 PM
  #417
Toby-22's Avatar
Toby-22
I have rays oem track wheels on my Z lowered by 1.5" maybe more (buddy club coils), and running 20mmf/25mmr wheel spacers. I was running 245/45 in the rears with no problems but ended having to roll the fenders with 255/45. IMO it looks sooo much better with the spacers. When i lowered the car, the wheels even with the spacers look tucked in I may need to go 30mm in rears,...or upgrade to 19" TE37s
Old Nov 7, 2008 | 05:40 PM
  #418
Imnu2dis's Avatar
Imnu2dis
Default My addition
Here is my graphite attempt:
Old Nov 7, 2008 | 07:57 PM
  #419
THe Emperor's Avatar
THe Emperor
Anyone have pictures of stock 17s with spacers?
Old Nov 16, 2008 | 09:24 PM
  #420
G3O's Avatar
G3O
Default my touring rims
did my 4 months ago
Attached Thumbnails OEM Wheel Modification Thread-picture-026.jpg   OEM Wheel Modification Thread-picture-027.jpg   OEM Wheel Modification Thread-picture-029.jpg   OEM Wheel Modification Thread-picture-039.jpg   OEM Wheel Modification Thread-picture-044.jpg
