can someone explain offset to me?
Old Apr 8, 2003 | 06:20 PM
ares's Avatar
ares
Veteran
Default can someone explain offset to me?
well Ive been catipulted into the rim market in the last week, so now I need to figure out what all this is.
what does it mean, what does a large offset mean vs a lower one?
how does 30 front, 35 back sound?
Old Apr 8, 2003 | 11:45 PM
veilside z's Avatar
veilside z
Hope this helps...
Check out the Yokohama site, it will walk you through the things you need to know - http://www.yokohamatire.com/utcustom.asp
Old Apr 9, 2003 | 07:16 AM
jj1814's Avatar
jj1814
Default Re: can someone explain offset to me?
Basically, the higher the number, the more the wheel sticks under the car. Most peeps are finding that a 30-35 offset makes the wheel sit flush with the wheel well - just right.
Old Apr 9, 2003 | 12:20 PM
jak's Avatar
jak
The stock 18" touring or performance wheels have a 31mm offset. Nissan 350Z is correct, if you go higher than 31mm the wheels will be closer to the suspension or "tucked in" and the lower you go below 31mm the wheel will be pushed out to the edge of the car as compared to stock.
I am running in the mid to upper 20s on my rears and they are close to flush with the fender.
Jeff
Old Apr 10, 2003 | 02:37 AM
zeroday's Avatar
zeroday
Jeff
Did you have to roll your fenders ?
Old Apr 10, 2003 | 04:27 AM
jak's Avatar
jak
zeroday,
No, I didn't have to roll the fenders. Everything fits fine no rubbing. I will be lowering the car also. I have about 1.5" of room before things start to rub.
Here are some pics: https://my350z.com/forum/showthread....&highlight=HRE
Jeff
Old Apr 10, 2003 | 05:05 AM
2003z's Avatar
2003z
Jeff
That is only true if you go with a rim of the same width. An 18x9 with +30 will stick out farther than an 18x8 with +30.
Also, stock offsets from the owners manual are
17s
17x7.5 +30 front, 17x8 +33 rear
18s
18x8 +30 front, 18x8 +30 rear
Track
18x8 +30 front, 18x8.5 +33 rear
Old Apr 10, 2003 | 05:58 AM
jak's Avatar
jak
2003z,
You are correct, different width rims produce different offsets. I found the owners manual numbers to be off slightly from actual measurements. The actual offset was +31.27mm measured with a digital micrometer. Close though.
Jeff
Old Apr 10, 2003 | 12:50 PM
2003z's Avatar
2003z
2003z,
Jeff
I stand corrected! You would think something like the owner's manual would have good info, though!
seagrasser
Oct 11, 2015 03:27 PM
irishguy0224
Sep 22, 2015 06:57 PM
