+36 and +43 offset will fit?
Old Mar 8, 2007 | 02:46 PM
sw0ng's Avatar
sw0ng
Default +36 and +43 offset will fit?
i have a set of volks GT-Cs, and they are
18x8 +36 and
18x10 +43
will these fit properly?
Old Mar 8, 2007 | 02:53 PM
Nexx's Avatar
Nexx
18x8 +36 and
18x10 +43
they should but they will be soooo sunken in. wheels spacers and you are good to go.
Old Mar 8, 2007 | 02:58 PM
smellslikecurry's Avatar
smellslikecurry
youd need to run a 20mm spacer all around
Old Mar 8, 2007 | 02:59 PM
sw0ng's Avatar
sw0ng
alrights, how much do you think itll cost?
Old Mar 8, 2007 | 03:00 PM
sw0ng's Avatar
sw0ng
and another question, whats the oem wheel offset?
Old Mar 8, 2007 | 03:01 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Mar 8, 2007 | 03:04 PM
Question
Not sure. What size wheels does the 2006 have?
Old Mar 8, 2007 | 03:15 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
I have 41mm in the back and it looks ok. Just like the OEM Rays 06/07 Grand Touring wheels. But then again my wheels are 19x10.5 in the back. What dimensions are your new wheels going to be.
Old Mar 8, 2007 | 05:00 PM
scotts300's Avatar
scotts300
Both will be ok but could use a spacer, ~15mm, to make flush with the fender. Those are better suited on a 300z.
Old Mar 8, 2007 | 05:05 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
OEM 18s 03-05 were +30 f/r. Not sure about the newer ones, but can't be too far off.
350z82
Oct 1, 2015 06:25 PM
