Help !1 Small Rotor Stud Bolt ??
Old Mar 25, 2007 | 03:35 PM
Agentman03's Avatar
Agentman03
Default Help !1 Small Rotor Stud Bolt ??
Help What is that extra small Bolt (stud) on the Rotors ??... wheel Lineup or what ?? 2003-2004 touring model
Old Mar 25, 2007 | 03:42 PM
cubu's Avatar
cubu
its so you don't mount the stock rear rims on the front
Old Mar 25, 2007 | 03:45 PM
drivenCSZ's Avatar
drivenCSZ
im pretty sure its there to confuse you, so you post without searching and then get flamed for asking an uber noob question thats been asked 1000 times.
and then next time you'll search. maybe.
and its there apparently because nissan techs among other people dont know that big wheels go in the back and small ones in the front...lol
Old Mar 25, 2007 | 03:56 PM
Eazzy's Avatar
Eazzy
All above true, But it is also handy if your rotor is difficult getting off due to rust, Screw a longer one in there and tighten it to "press" the rotor off the hub. Other vehicles use them, and they run the same wheels all around.
That info you may not find in the search
Old Mar 25, 2007 | 04:09 PM
jcpeyton's Avatar
jcpeyton
If it's preventing you from mounting aftermarket wheels. remove it and don't give it a second thought. There are lots of posts on this subject. Search a little, if for no other reason than the peace of mind that lots of us have removed it w/o issues.
Old Mar 25, 2007 | 04:12 PM
Agentman03's Avatar
Agentman03
Default Stud
Just was Trying out putting my 5 Bold Custom Mag Wheels off of my RX7 turbo coupe to see What they would look like ..would have to remove the studs ..
Old Mar 25, 2007 | 04:13 PM
Agentman03's Avatar
Agentman03
Sorry .. Thanks ...
Old Mar 25, 2007 | 04:24 PM
jcpeyton's Avatar
jcpeyton
No apology necessary. Hope the info helped.
Old Mar 25, 2007 | 04:26 PM
Agentman03's Avatar
Agentman03
Default No Stud ..drill & Slot Dude ...
My Rx-7 Wheels , No Stud ... Drill & Slotted Bremo Rotors, Guess That It's Time To throw Some on The " Z " ...
Attached Thumbnails Help !1  Small Rotor Stud Bolt ??-rx7_trotors1.jpg   Help !1  Small Rotor Stud Bolt ??-rx7_-_06-pict0b.jpg
Old Mar 25, 2007 | 04:29 PM
Agentman03's Avatar
Agentman03
Thank's Again .. End of Post ..
samansharif
Sep 25, 2015 12:31 PM
