Blue paint dot on new wheels
Old Mar 28, 2007 | 05:25 PM
sdl13's Avatar
sdl13
Default Blue paint dot on new wheels
My new 06 ZR has a blue paint dot on every wheel. Honestly I should have noticed before I took delivery but, It was night and I was too excited. Anyone know why they are there or how best to remove them?
06 SS ZR
Old Mar 28, 2007 | 05:57 PM
FibreGuy's Avatar
FibreGuy
That dot shows either the heavy or light area of the wheel. The tires should have had a dot also to indicate to opposite weight (light or heavy side). Those dots should be lined up. When they are and the assembly is balanced it should take very little weights to achieve balance.
Old Mar 28, 2007 | 06:01 PM
tomiegunzz's Avatar
tomiegunzz
? Say what?
Old Mar 28, 2007 | 06:08 PM
TheProfessional's Avatar
TheProfessional
FOR REAL WTF??
I have the same dots even after a year later.. looks like a job for a careful razor blade. GOOD LUCK!
Old Mar 28, 2007 | 06:45 PM
Scarab440's Avatar
Scarab440
he's right. its common on OEM wheels/tires. never seen it on aftermarket.
sry110's Avatar
sry110
Yeah my OEM 2006 wheels have that too. Definitely tried to scrape it off with a finger nail, that didn't work.
Old Mar 28, 2007 | 07:05 PM
Pooplet's Avatar
Pooplet
a fingernail worked on mine, Grow them out a bit.
Old Mar 28, 2007 | 07:09 PM
blueper4mancez's Avatar
blueper4mancez
damn guys just get some acetone or some gasoline and a paper towel , that should do the job .
Old Mar 28, 2007 | 07:15 PM
SteevoZ's Avatar
SteevoZ
i have the dots on my 2004 wheels also. Not as noticable as yours though.
Old Mar 28, 2007 | 07:37 PM
Phantom Menace's Avatar
Phantom Menace
Whew. I found mine the day after I took the car home and was wondering the same. I'll try the acetone or gasoline tomorrow. Thanks guys.
Old Mar 28, 2007 | 07:51 PM
tmak26b's Avatar
tmak26b
isnt that under the clear?
Old Mar 28, 2007 | 08:03 PM
blueper4mancez
dont use too much acetone , just pour it one the paper towel and scrub it off .
<< he knows his shizz (nail tech) lols
Old Mar 31, 2007 | 05:54 AM
ChinaClipper's Avatar
ChinaClipper
No! Fibreguy is correct. The mark is the heavy point of the OEM wheel. It is intended to be matched when mounted, to the dot on the tire, which is the lightest point of the tire. That way, the car manufacturer will save on the cost of extra wheel weights and labor to install them. Car companies look at EVERYTHING to save bux! The wheel dot is marked to the tire AFTER the clearcoat, so that the wheel is measured for balance as a last step in the wheel manufacturing process.
Old Mar 31, 2007 | 08:59 AM
Bevo's Avatar
Bevo
O.o too late i already scraped mine off
Obadabot
Jun 18, 2023 11:31 PM
