what spacers shoudl i get?
Old Apr 5, 2007 | 07:52 AM
sunthose802000's Avatar
sunthose802000
Default what spacers shoudl i get?
i have the track z. 2003. im am droping it soon on springs and shocks. tokico ajustables and h&r's. i am leaving the track stock wheels on the car. i want to bring the wheels out as far as possible. i know they have 25, 20, 15 and 5 mm spacers. not sure what will do the job. i really dont want to roll the fenders in the back. so im trying to get spacers that will just come out that far. im sure the springs are not that much of a drop. i think its like 1.2inch drop. i dont think there is a difference if i buy between ebiach, h&r. ichaban, or project kics spacers. unless you guys have your own opinion. i would like your input on this issue. also anybody out there have any deals on spacers? looking to get the shcoks soon too in the soming weeks. thank you
Old Apr 5, 2007 | 07:54 AM
THE TECH's Avatar
THE TECH
Screw spacers, just have the wheels widened.
Old Apr 5, 2007 | 08:06 AM
evolved326's Avatar
evolved326
I have never been a search **** but here it goes..SEARCH.
By far the easiest thing to search.
Old Apr 5, 2007 | 08:35 AM
redlude97's Avatar
redlude97
that still won't push the wheels further out towards the fender though
Old Apr 5, 2007 | 08:40 AM
THE TECH's Avatar
THE TECH
Of course it will. Just depends what portion of the wheel is widened.
Old Apr 5, 2007 | 08:52 AM
redlude97's Avatar
redlude97
wouldn't that require cutting the lip off the front of the wheel and widening from there? Its my understaning that they cut the section of the barrel behind the spokes and add in a section of metal there. That shouldn't change the position of the outer wheel surface once its bolted to the hub. There is one g35 owner that widened his 17" wheels to 10" and had to use spacers to push the wheel out further to get suspension clearance IIRC
Old Apr 5, 2007 | 08:56 AM
THE TECH's Avatar
THE TECH
Like I said, just depends on where they add the widened piece.
Old Apr 5, 2007 | 08:57 AM
AWDBall20's Avatar
AWDBall20
just save n get new rims....i did. 10.5 ftw!
Old Apr 5, 2007 | 10:04 AM
sunthose802000
i dont want rims. just want to track the car from time to time. might just sell the car and get something else later on. i just want pics of the car with spacers with stock wheels. and what is the widest i can go.
Old Apr 5, 2007 | 10:22 AM
JasonZ-YA's Avatar
JasonZ-YA
ive seen 20mm front and 25mm rear...looks good...
im thinking 25mm front, 30mm rear.....but may just do all 25mm.
-j
Old Apr 5, 2007 | 10:36 AM
redlude97's Avatar
redlude97
Spacers aren't going to help you on the track really, so if you really want to track it, save the money for some better tires
Old Apr 5, 2007 | 10:41 AM
redlude97's Avatar
redlude97
any links to places that will do this? I've never seen this done to the outside of a wheel before because it would look like ****. They would have to weld in plate, and then grind it flat
Old Apr 5, 2007 | 10:43 AM
sunthose802000
i see your point. the thing is i dont want to buy aftermarket wheels. in the mean time beter tires and wider stance is what im looking for. plus other suspension stuff. so 20 front and 25 rear huh? any pics anybody has ?
Old Apr 5, 2007 | 11:11 AM
z-u-later's Avatar
z-u-later
I have H&R Trak+ hubcentric spacers -- 20mm in front & 25mm in rear. Here are pictures of my Z with stock rims & tires:
And yes, the spacers do widen your stance a bit and helps with your handling performance.
Old Apr 5, 2007 | 01:31 PM
Don't make this too complicated. Spacers are for looks. If you want to move the front wheels 10 mm, and the rear 20 mm, just get the appropriate spacers. Who am I to tell you what looks best on your car.
Old Apr 5, 2007 | 03:58 PM
azula's Avatar
azula
^ur post count is amazing!!!
Old Apr 5, 2007 | 04:04 PM
wldkatz03's Avatar
wldkatz03
are you lowered? i want to do the same but i'm on eibach pro-kits and not sure if it's too far out?
Old Apr 6, 2007 | 08:03 PM
streetracer's Avatar
streetracer
the spacer will also depend on the tire size you use. I run a 255/40/18 and 265/40/18 setup and a 20mm spacer front will probably rub. On the rear the 25mm spacer is fine. I have seen it with a lowered car and the owner tells me it doesn't rub. when the suspension travels the wheel tucks inside the quarter panel.
Old Apr 7, 2007 | 06:23 AM
z-u-later's Avatar
z-u-later
Yes, in the picture, my Z is lowered ~1" with the Espelir Active GT springs.
Old Apr 24, 2007 | 11:51 AM
xProbeGTx's Avatar
xProbeGTx
Here's a couple pictures of my car with 25mm spacers on front & back. Stock rims dropped on Tanabe springs. It is possible to go 25mm all around & get no wheel rub under all road conditions.
FromGtoZ
Sep 20, 2015 03:41 PM
torchkc
Sep 11, 2015 08:26 PM
