they will look like crap, they have like a 45-50mm offset. Just buy them and take the tires off and get you a set of OEM 17"s then sell the rear rims in the Supra/ RX7 forum
Are you serious? If they are the same bolt pattern, they *can* fit. What's the offset?
Ever try and think on your own?
im gonna spend about 200 for these wheels... i might as well use them for a few passes and then i can sell them on the supra or rx7 forums... duhhhhh plus they have fresh drag radials... which probably cost $200 each new...
who cares what they look like...
IM GONNA USE THEM AT THE STRIP...
they question wasnt will they look good on my car...
the rim with that tire size will not fit. It has to high of an offset. It will hit your suspesion, that was actually the point I was trying to make. But it has a 275 then it will not fit the stockers. You see you didn't say what was the tire size in the first thread. So before you jump on people a$$ put all the info so we can give you a more educated answer.
