Offset 25mm/30mm ??
Old Apr 28, 2007 | 10:24 PM
JasonZ-YA's Avatar
JasonZ-YA
Default Offset 25mm/30mm ??
Q1: Has anyone tried this? if so, show me pics?
I have 06 wheels? 18's 225F AND 245R
Q2: and if so, do i need to roll fenders?
ive noticed most do 20mmF and 25mmR
but i want spacers w/ out changing studs..
Q3: Project kics spacers do this with 20mm for the front but will they work with 06 wheels? since they need that gap 4 clearance on the factory studs, due to only 20mm thickness?
-J
Old Apr 28, 2007 | 10:46 PM
JasonZ-YA's Avatar
JasonZ-YA
bumpity?
Old Apr 30, 2007 | 06:21 AM
QdotJ's Avatar
QdotJ
I'd like to get my 06's flush, or as close to flush, with the fenders as well.
B-U-M-P....
Old Apr 30, 2007 | 06:58 AM
Measure the distance between the top of the tire and inside of the fender. How much room do you have?
Old Apr 30, 2007 | 08:26 AM
cubu's Avatar
cubu
doesn't the stock rims have space for the protruding studs on the bolt-on spacers?
Old Apr 30, 2007 | 07:23 PM
JasonZ-YA's Avatar
JasonZ-YA
anyone?
Old Apr 30, 2007 | 07:24 PM
JasonZ-YA's Avatar
JasonZ-YA
it looks like they do! but i was hope'n to find out a definate answer from someone thats already tried it?
my350z.com let me know?!?!
- Jason
Old Apr 30, 2007 | 07:25 PM
JasonZ-YA's Avatar
JasonZ-YA
and if anyone out there does have this set up? post some pics?!
- j
Old Apr 30, 2007 | 07:30 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
theres lil info here:
https://my350z.com/forum/showthread....=wheel+spacers
way more here
https://my350z.com/forum/search.php
Old May 1, 2007 | 01:40 PM
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by myZter
YA, i did that...
looking for someone with pics or experience doing this on stock 06 wheels.
- j
Old May 1, 2007 | 01:42 PM
Nihilation's Avatar
Nihilation
I'd like to know how those two links that myZter provided did not help...
Old May 1, 2007 | 03:11 PM
JasonZ-YA's Avatar
JasonZ-YA
I read them! understand them....but i think i made it clear i was reaching out to the my350z community to see if any one has pictures or can give feed back on 25mmF/30mmR set up.
pics would be nice.
- J
Im thinking since know one has hit.. ill probably purchase some 25mm. mount them on the front and try them out....if they look good then ill keep them and purchase some 30mm for the rear.....
if the 25mm i purchase dont look good, ill DO the norm that everyone seems to be doing, which is 20mm Fronts and 25 mm rears.
the way i see it, either way i have to purchase at least one set of 25mm spacers!
Im trying to purchase spacers that go over the stock lug nuts and DO NOT REQUIRE longer studs. Im planning on buying many wheels for drifting and i will be removing the spacers quite often, plus i dont like the look of long studs.
The spacers are gonna be for my daily driving 06 wheels. And the spacers are gonna NOT be used on my correct offset aftermarket set of wheels i will be using for drifting and autoX.
I would really like to hear from someone that has 25F/30R, and if they have pics?
- J
Old May 1, 2007 | 03:22 PM
azula's Avatar
azula
i am interested in this too, i think i may need 25mm in the rear though, i have to measure still.
Old May 1, 2007 | 04:18 PM
JasonZ-YA's Avatar
JasonZ-YA
cool! im hope'n this thread helps us out sooner or later....
-j
Old May 2, 2007 | 09:20 AM
QdotJ's Avatar
QdotJ
-j
I like the look of 25mm for rears, but something about 30mm seems intriguing.
BUMP! To-The-Top
Old May 2, 2007 | 11:04 AM
cambo350z's Avatar
cambo350z
i just purchased 25mm H&R trak spacers for the rear that are bolt on that don't require longer studs(the 20mm do for some reason) and ordered 20mm eibach spacers for the front type4 that are bolt on's also..Im still waiting for them since the eibachs are on backorder...got them from mynismo.com. part # for h&r are 5065662, and eibachs are #90.4.20.003.4 click on the more info tabs on the website and it will show you the different types of how they attach..I will post pics once i get them on.hopefully in 2 wks..they say they will get my eibachs in this friday so should get them end of next week.
Old May 2, 2007 | 11:27 AM
cubu's Avatar
cubu
- Jason
you can easily check this yourself. just unbolt the wheel and take it off, turn it 1/10th of a turn and stick the rim up to the studs and see if the studs will go into the gaps
Old May 9, 2007 | 05:18 PM
big jon's Avatar
big jon
hate to say it but you'll never see the 5mm difference! thats intriguing!
seagrasser
Oct 11, 2015 03:27 PM
etong
Sep 10, 2015 06:14 PM
