Alignment needed? New 19" wheels
Old Jun 7, 2007 | 05:11 AM
Seel's Avatar
Seel
Default Alignment needed? New 19" wheels
I'm going from the stock 17" rims to 19's next week. Am I going to need to get an alignment done? Stock suspension
Old Jun 7, 2007 | 05:21 AM
Lawy'dU's Avatar
Lawy'dU
of course!!!
Old Jun 7, 2007 | 05:57 AM
Seel's Avatar
Seel
Anyone else?
The reason I'm asking is that I've asked a lot of people if they had done one and they will say no most of the time.
Old Jun 7, 2007 | 07:22 AM
tonester1011's Avatar
tonester1011
CF God
i didnt when i got my 19's...i had 17's before.
Old Jun 7, 2007 | 08:07 AM
z350boy's Avatar
z350boy
If you plan to do it right you do!!! Not only do you need an alignment but in order to maintain stock specs you will need Toe Bolts & Radius arms for the rear; SPC are the industry leaders. And up front and adjustable A-arm is needed; SPC or Cusco are good. Change the parts THEN do the alignment.
Old Jun 7, 2007 | 08:12 AM
tonester1011
CF God
i did do an alignment though after i dropped the car which was a few weeks later so it worked out good for me
Old Jun 7, 2007 | 08:23 AM
Seel's Avatar
Seel
That's false brother. You can get into spec without hardware. Many people can get into spec again after drops less than 1 inch without any hardware at all.
Old Jun 7, 2007 | 08:36 AM
tonester1011
CF God
oh yea, i was fine with all stock except for the eibach springs!
Old Jun 7, 2007 | 09:21 AM
Seel's Avatar
Seel
I don't understand your post, sorry. You can read it a couple of way.
Oh yea Im going to need an alignment??? Oh yeah I'm going to be fine as long as I'm on stock suspension???
Old Jun 7, 2007 | 09:38 AM
tonester1011
CF God
sorry...i installed the eibachs and when i did the alignment i did not need anything else...everything was fine with just running the eibachs...and just switching to 19's u may need an alingment, but nothing else. hope that clears it up.
Old Jun 7, 2007 | 09:56 AM
Lawy'dU's Avatar
Lawy'dU
OMG!!! This is such a newb question. Whenever you install different wheels and or tires, or different springs, etc. you should get an alignment. Just do it and stop asking. Any tech will tell you this.
Old Jun 7, 2007 | 10:01 AM
Seel's Avatar
Seel
I'll ask whenever I please. The more opinions the better. If you don't like it don't respond.
Old Jun 7, 2007 | 10:32 AM
Seel's Avatar
Seel
Is getting back to factory spec alignment the best thing to do?
Old Jun 7, 2007 | 07:08 PM
Marino Z's Avatar
Marino Z
Know it all
no allignment needed as long as no work to suspension.
Old Jun 8, 2007 | 05:51 AM
Seel's Avatar
Seel
You see, another opinion that says "no". My original thought on it would be that I wouldn't need an alignment. I'm still looking for more opinions.
Old Jun 8, 2007 | 08:34 AM
tonester1011
CF God
bigger wheels does not need alignment...only if u lower it do an alignment...im sure some people will say that when u get wider and bigger wheels u SHOULD do it, but it is not necessary.
Old Jun 8, 2007 | 08:39 AM
plastiketa's Avatar
plastiketa
I'd do it just in case. Have the tech give you a read out of where you are at now and you can decide then.
You gotta remember that every car is slightly different and a little precaution never hurts (only in the wallet).
Old Jun 8, 2007 | 08:53 AM
DavesZ#3's Avatar
DavesZ#3
Unless you change offsets or diameters (OD of tires, I assume), I was told by my shop that you don't need an alignment based on tires/wheels change. Obviously, if you lower the car you will need an alignment.
Old Jun 8, 2007 | 09:00 AM
World Famous Z's Avatar
World Famous Z
If you change out JUST wheels and tires, and not touch your suspension, no you do not need an alignment.
Old Jun 8, 2007 | 10:27 AM
Seel's Avatar
Seel
It's official now to me. Thanks Dave and Tony!
