285/40/18 or 295/35/18?
Old Jun 23, 2007 | 02:47 PM
007gt's Avatar
007gt
Default 285/40/18 or 295/35/18?
hi,
i am looking for KDW2 rear tires,
the rims are nismo lm gt4s, 18x9.5,
so you guys think which one is better?
thanks!
Old Jun 23, 2007 | 02:48 PM
jadaniya's Avatar
jadaniya
Originally Posted by 007gt
hi,
thanks!
i wouldn't get 40's, they will be too fat.
Old Jun 23, 2007 | 02:52 PM
007gt's Avatar
007gt
but the stock tire sizes are 225/45/18 and 245/45/18,
so 40 is still fat?
Old Jun 23, 2007 | 03:05 PM
JETPILOT's Avatar
JETPILOT
Learn the meaning of tire aspect RATIO. The ratio is a %. 40 is too high an aspect ratio for a 295 18 tire. 295 is too wide for a 9.5" wide rim
JET
Old Jun 23, 2007 | 03:06 PM
ppw350Zunit's Avatar
ppw350Zunit
neither....how about 285/35 instead?!?!
Old Jun 23, 2007 | 03:30 PM
007gt's Avatar
007gt
JET
thanks..
so, 285/40/18 is ok?
Old Jun 23, 2007 | 03:54 PM
original786's Avatar
original786
hey sorry to bud in, but i have the same consern, i have nismo bronze wheels, and one of my rear tires gave out on me after having them for 6 months, hahah i love boost, thats what boost does to your car, eats your tires..
any how i had 275-40-18 on my nismo , on my rear
i was wondering as well is 285-40 going to be to wide? or to fat
or should i go 285-35??
or stick with 275-40-18??
Old Jun 23, 2007 | 04:33 PM
What about the tire size recommended by NISMO?
Old Jun 23, 2007 | 05:15 PM
original786
245-40 and 275-40 recommended by nismo
Old Jun 23, 2007 | 05:26 PM
Zridder19's Avatar
Zridder19
Stick with 245/40 285/35 combo, its the same overall diameter and looks great.... Heres some pics of my setup.
https://my350z.com/forum/showthread....64#post3961764
Old Jun 23, 2007 | 05:29 PM
rcdash's Avatar
rcdash
Go look at the tire specs on tirerack and look for the min/max/recommended rim widths and then try to pick a tire where the profile height (which is equal to the width * ratio) = 110 in the rear and 101 in the front to prevent your speedo from reading incorrectly. Keep the stagger even if you go higher or lower to prevent issues w/ VDC.
Or if you don't want to do the work, for a 9.5" rim, I think 275/40/18 is what you should get if you want to stick to specs (w/ a 255/40/18 front).
Old Jun 23, 2007 | 06:41 PM
DavesZ#3's Avatar
DavesZ#3
The 9½" rim is at the lower limit of the recommended wheel size for the 285/40. The lower limit for the 295/35 is 10" so that's out.
The 285 will be squeezed onto that 9½" wheel - 275 might be a better fitting choice.
Atl300zx
Sep 23, 2008 06:44 AM
bleachberu
Dec 15, 2006 01:41 PM
