Goodyear Eagle F1 GS-D3
Wat about Goodyear Eagle F1 GS-D3 in 255/35/19 front and 275/35/19 in the rear on 19x9.5 in the front and 19x10.5 in the rear with +22 offset
Would this be a good setup for a non tracked non racing daily driver??
stretched tire looks roughly like this:
tire ------> /__\
wheel ----> l___l
Not sure exactly what sizes you would probably need because it really depends on your setup, ie wheel offset, lowered or not, etc. But i would definitely go for a wider set of tires.
tire ------> /__\
wheel ----> l___l
Originally Posted by nothingremains
Wat about Goodyear Eagle F1 GS-D3 in 255/35/19 front and 275/35/19 in the rear on 19x9.5 in the front and 19x10.5 in the rear?
I just checked the specs on the tires. Those tires should fit on your wheels w/o a problem. (-although your tires ar a little on the wide side of the range)
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
im just going to take it to the nissan dealership..and im going to order the tires off tirerack..i was going to take the rims and tires on friday to get them put on...so 285/35 is just a little wider then 275?
AlvinHuyN
North West
Apr 24, 2007 09:40 PM
