Tires question
Old Jul 26, 2007 | 09:07 AM
GRAY350Z07's Avatar
GRAY350Z07
Default Tires question
Planning on Rota P45R 18X9.5
subydude.com said:
front: 275/35/18
rear: 295/35/18
What do you guys recommend? Also I plan to get TEIN Type S spring.
T
Old Jul 26, 2007 | 09:09 AM
DavesZ#3's Avatar
DavesZ#3
A lot depends on what kind of driving you plan on doing but the normal up-sized 18" tires are 245/40/18 and 275/40/18. 295 sounds too wide for 9½" wheel.
Old Jul 26, 2007 | 09:33 AM
GRAY350Z07's Avatar
GRAY350Z07
my driving is basically daily driven,
maybe a little push here and there
but just the norm driving
so you recommend 275 in the rear, and 255 or 265 in the front?
Old Jul 26, 2007 | 02:15 PM
DavesZ#3's Avatar
DavesZ#3
The next step up would be like 255/35 and 285/35. That size is significantly "shorter" than stock so you'll have some speedo/odometer error.
285's are about the widest recommended for a 9½" wheel. While you could use wider in certain situations (autocross, drag), you don't want to go to extremes for a daily driver.
Old Jul 26, 2007 | 08:53 PM
terrasmak's Avatar
255/40 and 275/40's will be perfect
Old Jul 26, 2007 | 08:54 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
295s you're going to need a 10.5" wheel on the rears. 275s should be your limit on 9.5"
Old Jul 26, 2007 | 08:56 PM
black06z's Avatar
black06z
What about 265/35/18 all around?
Old Jul 26, 2007 | 10:47 PM
terrasmak's Avatar
VDC will like 275's better in the rear , so yes you could do 265/35 front and 275/35 rears..
Old Jul 26, 2007 | 11:15 PM
WheelDude.com's Avatar
WheelDude.com
Vendor - Former Vendor
For a daily driven car with 18x9.5 all around I would recommend 255 or 265/35/18 front and 275/35/18 rear. The 275 and 295 combo is more for an aggressive street/track setup.
-Dan
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Mattg350z
Oct 2, 2015 06:51 AM
