Anyway to cancel out the TPMS light w/o TPMS in car?
the touching the sensor puts power into the sensor via the tip and turns them "on" and sending a signal. because otherwise they dont send a signal until 36mph. as far as me installing my tpms in my wheels. i had them in the first set and then a road transition broke 2 sensors cause the tires were 25 series.. and so i tried to mount the sensors instead of band them but with the wheel design the didnt sit at right angle and leaked. so installing them isnt a solution i want to use. i got it figured out what ima do now the weather needs to cool down cause im not gon sit in car in 110 heat
Originally Posted by DavesZ#3
I see your dilemma. The description in the service manual states that the tech much touch the activation tool to the transmitter. I assume that it won't work once you have them inside the wheel. I would double-check with the service department before you do anything.
randy
Originally Posted by woof*
thats what i was worried about Dave, thanks for the reply. i'll call a dealer.
randy
randy
Vigman
Nov 17, 2015 04:34 AM
350Z Project X
Oct 17, 2015 05:16 PM
