Need input: Horrible steering wheel vibration.
Old Sep 17, 2007 | 06:45 PM
meaj82's Avatar
meaj82
Default Need input: Horrible steering wheel vibration.
Alright, here is the deal. I just got some 19" g35 rays recently. I had them installed last week. At first I had horrible shaking and the car felt very awkward. I went back to get a rebalance with the master tech. All the tires were off.
He fixed it up and the ride feels alot better, but the steering wheel shakes very bad above 70+mph. The rear tires are brand new and the front are used. I'm going back for an alighnment later during the week too.
He did notice some high low spots on the inner part of the front tires, but is it enough to shake that bad at those speeds? I mean it moves my hands like I am holding on to a lawnmower . Anyone care to chime in?
Old Sep 17, 2007 | 06:50 PM
Sean's Avatar
Sean
were the tires high speed balanced?
Old Sep 17, 2007 | 06:52 PM
meaj82's Avatar
meaj82
yep.
Old Sep 17, 2007 | 06:53 PM
SuperBlack350z's Avatar
SuperBlack350z
were the right rims and tires put on? Did you tell him they are staggered?
Old Sep 17, 2007 | 06:54 PM
meaj82's Avatar
meaj82
Yeah, they saw that before I mentioned it.
Old Sep 17, 2007 | 06:56 PM
SuperBlack350z
well, the two main reason why steering wheel shakes is because of the tires not being balanced and the rims not being hubcentric...and since you have the g35, i'm guessing they are. So the next thing would be seeing if you have bent rims.
Old Sep 17, 2007 | 07:01 PM
Sean's Avatar
Sean
flat spots (from skidding stops) will also do it
Old Sep 17, 2007 | 07:02 PM
meaj82's Avatar
meaj82
Superblack350:
Forgot to mention he did look for that as well. Anthoer thing, ever since I put on the wheels my car pulls to the right. What about the low high spots on the inner part of the tire? Will that cause anything?
Old Sep 17, 2007 | 07:07 PM
simonfencer's Avatar
simonfencer
If the fronts are used they might be completely shot.
If you have a spare set of front wheels and tires I would put them on to see if it isn't, just by coincidence, something mechanical in the steering or suspension.
Old Sep 17, 2007 | 07:08 PM
SuperBlack350z
Originally Posted by meaj82
Superblack350:
Yeah, i mean, worn tires due to bad camber will cause steering shake but not bad as you are stating (like a lawnmower).
Also, it would take a pretty extreme flatspot to get bad wheel steering wheel shake. Flat spots kinda make your car feel rough, not necessarily with the steering. I had a good flat spot before because my brakes locked up but it didn't even cause the steering wheel to shake.
Get an alignment. Since you said it pulls the the right.
Old Sep 17, 2007 | 07:13 PM
meaj82's Avatar
meaj82
I still have my stock wheels and tires. They never gave me any problems. I might try that out.
Old Sep 17, 2007 | 07:17 PM
meaj82's Avatar
meaj82
Will flatspots make a car feel like you are driving on a bumpy road even though its smooth?
Old Sep 17, 2007 | 07:29 PM
wayneside's Avatar
wayneside
the flat spots will do it...or the balance is off. have someone else check the balance. the wheels may have been repaired at one time...if so, one of the wheels may be warped.
sorry to hear!!!
Old Sep 17, 2007 | 07:38 PM
redman333's Avatar
redman333
Yeah, depending on how bad the flat spot is.
Old Sep 17, 2007 | 07:40 PM
meaj82's Avatar
meaj82
^^^^^I saw the master tech do the balancing and he was pissed off at what his workers did last week. He even took the time to show me what was wrong and how it is suppose to be. This is driving me nuts!
Old Sep 18, 2007 | 08:17 AM
meaj82's Avatar
meaj82
bump for more info.
Old Sep 21, 2007 | 04:12 PM
meaj82's Avatar
meaj82
Default update
Well I had the tires rotated on the front. It seems to have helped a little. The tires do look pretty bad now that the inner part is showing on the outside. He noticed a very small dent that I could not tell it was there. Sigh I hate driving my z like this.
Old Sep 21, 2007 | 04:21 PM
wayneside's Avatar
wayneside
new tires will probably solve the problem...
Old Sep 21, 2007 | 04:26 PM
Spike100's Avatar
Spike100
^^ I'll bet it's the tires.
--Spike
Old Sep 22, 2007 | 07:00 AM
meaj82's Avatar
meaj82
I hope so . Thats what I'm planning to do next. Damn!! there goes my mrev2 and spacer
Just to get some re-assurance. The small dent that he could see and I could not even make out. That should not cause anything. Right?
