Anyone know who makes these wheels?
I haven't posted much...but this was before I finally got a Z of my own.
So I was browsing for wheels today and came across these. The pics say VMR wheels and I did a search on them and found they only sell this wheel for Euro cars. Never heard of them, but regardless I think they look pretty damn good what do you guys think?
I'm sorry to be a noob, but I did do an extensive search on google and was only able to find pictures of these wheels on Euro cars. If you could point me in the right direction or give me more information on these wheels I definitely appreciate it. tia
you don't make wheels for euro cars or jdm cars, you make them for offsets and bolt patterns
if the rims have the same bolt pattern, the hub hole (no idea what it is called for some reason, but the center open area where the centercap goes) we do and are in our offset range, you are set.
also, let me say that I would like those rims if the spokes didn't curve in at the lip.
Originally Posted by StreetOC192
An Infinity G35 coupe is a Euro car?
Well here's info I found on the sizes available for this wheel:
Size / Bolt Pattern / Offset / Lip / Weight
19x8.5 / 5x120 / +38 / 2.25" / 26 lbs
19x9.5 / 5x120 / +45, +22, +30 / 3.0" / 26.5 lbs
So it looks like the best setup you will get for a Z would be:
Front - 19x8.5 +38 (maybe you can use a 15mm spacer)
Rear - 19x9.5 +22 (not bad, but maybe use a 10mm spacer to go more aggressive if desired)
This setup will run you 998.99 at http://www.modbargains.com/product.a...elocityV715_PR
I would run the 19x9.5+22 all around. the front fitment is lame.
Might not look bad now that I think about it again. Perhaps someone with some photochop skillzzzzz can help out with the visual?
If I can get a set for as much as they listed...that would be a steal for a set of wheels like these!
Tochigi_236
Sep 27, 2015 03:40 PM
