tps problem. please help
Old Nov 14, 2007 | 06:51 PM
ilbkuup's Avatar
ilbkuup
Newbie
Default tps problem. please help
ok , i have read the thread "read this gefore you post about tps". here is the situation.
I installed LE37's w/o tps about three years ago and never had this problem. i never transferred the sensors from the oem rims. i did have the light come on after driving after 30 or so minutes.
last week i had new rubber installed and was going to install the sensors out of my old oem rims. i had the taken out of the wheels and the tech ended up breaking one. so final result i didn't have them installed after all. my dumbass drove from the shop home with the sensors in my car. the warning signal and light came on because they were reading no pressure due to being out in the open in the z.
took them out of the car and went to the dealership to reset the system. warning light and signal was cleared for the first start up. drove about 20 miles got out for about a half hour and then started it up agian and had the light and the psi blinker came on again. grrr.
same set up that i have been running for years and never had this problem. how do i fix it? please help. i thought that reseting it would take care of this. i thought i would have the light come on after not getting signal after drive time like it has done for years.
Old Nov 14, 2007 | 07:17 PM
Spike100's Avatar
Spike100
Your message is confusing.
Question: You said: "my dumbass drove from the shop home with the sensors..." ...Who is the "dumbass" you refer to here?
Your solution is being certain you have 4 working sensors that the dealer can calibrate.
--Spike
Old Nov 14, 2007 | 07:41 PM
cheshirecat79's Avatar
cheshirecat79
I'm having a hard time deciphering this question.
Old Nov 15, 2007 | 03:34 AM
DavesZ#3's Avatar
DavesZ#3
If they are sitting inside your car, then it has the same effect as sitting at home in the garage. They don't transmit all the time. They have centrifugal switches that cause them to go on and start transmitting when the speed gets above around 20mph. Your warning light came on because it's still not getting a signal even though the sensors are IN the car.
Old Nov 15, 2007 | 05:28 AM
ilbkuup's Avatar
ilbkuup
Newbie
sorry if i wasn't clear. i am a terrible writer.
i had the sensors in the cabin of the z not the wheels when i drove home from the shop. this made the warning go off. i took them out of the car and went to the dealership and had the system reset.
the warning light did not come on the first start up after leaving the dealership. but the second start up it came on right away.
i have ran this way without sensors for over three years and have never had the warning light come on right away. it usually comes on after about 30 mins of driving. now it has begun to have the psi light blinking which has never happened as well as the tps light.
Old Nov 15, 2007 | 09:08 AM
DavesZ#3's Avatar
DavesZ#3
Maybe it had something to do with the fact that the dealer reset the system, but it never got a clean signal from the sensors since they aren't installed.
Old Nov 15, 2007 | 09:24 AM
ilbkuup's Avatar
ilbkuup
Newbie
that makes sense. damn it. if i would have kept them clear of my car i wouldn't have this problem now. i'm stupid. thanks dave.
Old Nov 16, 2007 | 11:23 AM
supernadc2's Avatar
supernadc2
wait.. im about to kind of go through this and i was throw off by the question above..
I just bought the TE Time Attacks and i really dont want to put the tps system onto the new rims so what would happen if i didnt? Would the {!} be on all the time or could i have it reset once and never have to worry about it again? If theres anyone out there who swapped wheels and didnt put the tps back on please let me know what the results are.
Old Nov 16, 2007 | 11:36 AM
ilbkuup's Avatar
ilbkuup
Newbie
your (!) light will come on about 30 minutes after driving. then turn off when you turn off the car. just make sure you keep the sensors clear of the car.
Old Nov 22, 2007 | 12:45 PM
gti303's Avatar
gti303
hmm...what happens to the TPS system if you lets say...rotate your tires from front to rear...will they still read?
Old Nov 22, 2007 | 01:20 PM
DavesZ#3's Avatar
DavesZ#3
Yes, but now the readout on the display will be swapped around. The sensors are in each wheel, and the computer "knows" them by a unique ID number. Each ID is associated with a corner of the car. If you move them around, the computer doesn't know so you'd have to keep track of the positions.
BTW - normally we don't rotate wheels on the Z because of the staggered tire setup so this isn't usually a problem.
Old Nov 22, 2007 | 02:28 PM
cbr900son's Avatar
cbr900son
Is this true. Cause ive been having prob with the sensors breaking (8k miles) and already replaced 2 and waiting on a third. Im also about to buy aftermarket rims and bout to say the hell with them especially if no (!) light.
Old Nov 22, 2007 | 02:34 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
why would you? their staggered so the backs are wider then the fronts, if im not mistaken, therefore the only way to "rotate" your tires are going from left to right or vice versa, but you would also have to unmount the rim from the tire, flip the tire, put back on the wheel, and then move the wheel to the other side of the car...if im not mistaken
liqalu04
Jan 2, 2022 12:58 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Uriyo_
Sep 8, 2021 08:46 AM
3vilbunny
Jul 18, 2017 05:10 PM
samansharif
Sep 25, 2015 12:31 PM
