Aggressive Wheels and Stretched Tires....Welcome
Old Dec 21, 2012 | 10:36 AM
  #21421
KingBaby's Avatar
KingBaby
Hardest Setting
dunno then maybe more lefts than rights or vice a versa
Old Dec 21, 2012 | 05:22 PM
  #21422
-miltdoggie-'s Avatar
-miltdoggie-
How I'm rolling...
Old Dec 21, 2012 | 05:35 PM
  #21423
TehkMob's Avatar
TehkMob
Originally Posted by JDMStanced
it is the front that's having problem now.
i have camber arm and toe arms in the back.
I only have like -3~-3.5 camber front and rear.. toes are set within the factory spec.
My previous tires also had the inner tire wear issue... because of the toe alignment.. It's weird that front toe is changing too easily..
Im sure its the toe on the frot.. The front tierods arent fantastic. Tie makes a replacement thats a little beefier that will help with it coming out of Toe.
Old Dec 22, 2012 | 08:14 AM
  #21424
potato's Avatar
potato
washing my car should get more interesting when i go lower in the front.
Old Dec 22, 2012 | 11:17 AM
  #21425
litoflow's Avatar
litoflow
Originally Posted by KingBaby
Really lol shoots grabbed it from Wfc Hawaii section thought it was that -69 offset wheels he was tryna fit lmao
nope thats my z on that pic messing around with 18x12-48 w/ 275/35. see them quarters? thats my signature :P
Old Dec 22, 2012 | 11:56 AM
  #21426
KingBaby's Avatar
KingBaby
Hardest Setting
Yea can't seem to find a picture of his attempt at tucking his last set!
Old Dec 22, 2012 | 06:32 PM
  #21427
TehkMob's Avatar
TehkMob
Wheels for sale, PM me if interested.
Old Dec 22, 2012 | 11:26 PM
  #21428
LeviEubanks's Avatar
LeviEubanks
For those of you running -5 to -6 degrees of camber in the rear? What toe arms are you using to correct your toe?
Old Dec 23, 2012 | 06:47 AM
  #21429
Rouse350z's Avatar
Rouse350z
im just running the spc toe bolts, and they do fine for me. im considering of getting the spl toe arms though.
Old Dec 23, 2012 | 02:43 PM
  #21430
TehkMob's Avatar
TehkMob
Damn she low ...
Old Dec 23, 2012 | 03:30 PM
  #21431
Token_Z33's Avatar
Token_Z33
i run Stance toe arms..work great for me
Old Dec 23, 2012 | 04:11 PM
  #21432
GenX350z's Avatar
GenX350z
just like they said, your tires wear out because of toe. believe it or not, ive never had problems with my tires wearing out unevenly. ive ran to -7 degrees before and have had no problems. if you cant afford SPL's run a toe bolt, it works as good. dont cheap out on anything NOW and youll be fine in the future!
HAPPY HOLIDAYS MY350Z FAM!
heres me on 18's. stock bumper with nismo lip.
Old Dec 23, 2012 | 04:14 PM
  #21433
microsteve40's Avatar
microsteve40
Know it all
Lovin that color!
Old Dec 23, 2012 | 05:07 PM
  #21434
Token_Z33's Avatar
Token_Z33
Old Dec 23, 2012 | 08:28 PM
  #21435
LeviEubanks
I'm purchasing a set of SPL Toe Arms. My rear toe is out by no more than 1/4 of a degree. It's so close, but my SPC Toe Bolts won't go any further.
Old Dec 23, 2012 | 08:46 PM
  #21436
katyboi's Avatar
katyboi
I'm running -5 on spc camber arms and didn't have to install my spc bolts. The shop here in houston aligned it just fine, hope that helps.
I'm a little old school so I've always loved carbon fiber on my cars, but is a little carbon fiber to much?
I got a Seibon oem cf hood, MasterGrade cf rear diffuser, was wondering if a CF hatch would be too much?
Your thoughts my350z, thanks
-Lewis-
Old Dec 23, 2012 | 09:28 PM
  #21437
Z_enthusiast's Avatar
Z_enthusiast
The more camber u run the easier toe can be put in spec... If your on a spring bucket.
Old Dec 23, 2012 | 09:51 PM
  #21438
Lexo350z's Avatar
Lexo350z
This is going to be a very newbie question. I'm planning on picking up a Z here pretty soon and wanna go aggressive as soon as I can get the funds to put something together. So here's the question
Is everyone here running the stance gr coilovers and a lot of the lips are fat but was wondering are most of them 3-4" front and 4-5" rear? Also running 19x10 front and 19x11 rear and just dropping it does it need camber kit right away? Thanks in advance also these cars are bad asses and have always been a fan of these cars hopefully I will be rockin in this club with the bad boys soon.
Old Dec 24, 2012 | 06:15 AM
  #21439
potato's Avatar
potato
lip size will depend on the offset, disk size, and wheel width. not eveyone rides on stance however I do and would recommend them. camber will depend on the aggressiveness of the wheel however while you go lower you will add natural camber in your oem kit. i suggest you look at http://www.rimtuck.com/ to see what some others are running and how it looks. you'll need to experiment yourself from there
Old Dec 24, 2012 | 06:38 AM
  #21440
TehkMob's Avatar
TehkMob
You could just buy My Z... its already sexy.
