Aggressive Wheels and Stretched Tires....Welcome
Have any of you guys run into issues with mashing the chit out of your harnesses in you wheel well up front?
My girl destroyed the back of her headlight and body harness, so now we're trying to find the connectors, clips, and body harness to cut and wire everything back together. Just curious if anyone else has had this happen and how they solved it. I'm looking on eBay right now for a headlight harness for 06+ headlights.
Is this lady-driven little guy low enough?
But on a more serious note, I'm no where near maxed on my coils, want to go lower, but I'm not sure the fronts can handle anymore. I'm 18x9.5 +5 225/45/18. I rub like a **** to begin with. How are you guys achieving flushness statically? Do I need more poke? Ignore the rear, fenders aren't rolled yet so I'm waiting to find a roller >.>
My set up isn't as aggressive as others and it might not belong here, but here it is.
Specs are:
Front: 19x9.5 +4 245/35
Rear: 19x10.5 +5 275/35
I would go lower, but the roads here aren't the greatest; there are more potholes than leveled road.
Specs are:
Are you cambered front and rear? It looks like you can tuck tires if you wanted to lower more.
I got 19x9.5/10.5 (+4f, +5r) and same spec tires and I can't tuck unless I camber a bit front and rear. Right now I'm poking about half an inch maybe a little more.
I'm lowered about the same height as you I think basing off of the pictures. I have about a finger gap between tire and fender/quarter panel.
