Aggressive Wheels and Stretched Tires....Welcome
Old Apr 7, 2014 | 01:16 PM
  #23281
juvi22003's Avatar
juvi22003
Originally Posted by driftsucky
With NO camber, you probably can't get too far past 11inches wide and MAYBE -5ish. However, you add some camber and you can get in the foot range. I'm at 18x12 -2 with just a roll (slight pull from driftin and rubbin)
Ok so say i go with 18 or 19 by 9.5 front and 10.5 or 11 in the rear the lowest offset would be around -5?
Old Apr 7, 2014 | 05:49 PM
  #23282
driftsucky's Avatar
driftsucky
In that realm. Anything more than that will require a bit more attention. Again, it's not a lot required. A pull and some camber can allow a bit more. You got any idea on tires cuz I'm sure you're aware a stretch will be required.
Old Apr 8, 2014 | 07:45 AM
  #23283
fataLblitz's Avatar
fataLblitz
I was able to run 19x9.5/10.5 +7 all around with just a fender roll, no pull and not have to have front camber adjusted. Rear camber was about -2.5.
If you go with an 11" or more in the rear, you'll definitely need more negative camber if the offsets are under +5. Also depends on the tire sizes you choose, I was running 255 on the 10.5 and it wasn't a crazy stretch, just enough to clear from rubbing in the rear.
Currently, i'm running an 11.5 +5 in the rear with 255/35 tires and I have to run about -3.5 camber.
Old Apr 8, 2014 | 08:17 AM
  #23284
juvi22003's Avatar
juvi22003
Thanks guys this helped a lot, usually i run 215 or 225 on my 9.5, 245 35 on my 10.5 and 255 or 265 on my 11.
Taking notes so as soon as i'm done with my IS i will get started on my Z.
Old Apr 8, 2014 | 10:58 AM
  #23285
driftsucky's Avatar
driftsucky
glad to help. The Z has more camber than the IS from the factory, so, if you keep everything relative, you'll see a larger offset available in the Z. However, all of this changes if you've got brembos. It changes the game.
Old Apr 8, 2014 | 12:21 PM
  #23286
cibon32's Avatar
cibon32
f1c1f761-a359-4b26-862b-943100815d20.jpg?t=1396919101
18x11 -2 offset with 10mm spacers.
Old Apr 8, 2014 | 09:43 PM
  #23287
Corey45810's Avatar
Corey45810
Old Apr 10, 2014 | 02:37 PM
  #23288
BSERIEuS's Avatar
BSERIEuS
George!
it's looking good!
Glad you're taking good care of her!
keep me posted if you still have my number.
-Ryan
Old Apr 13, 2014 | 10:10 AM
  #23289
cj0's Avatar
cj0
Does anyone know if a 19x11 +11 fits up front with a aggressive roll ?
Old Apr 13, 2014 | 11:27 AM
  #23290
mrfobbyaccent's Avatar
mrfobbyaccent
That will fit in the front with no fender work needed, assuming that your going to stretch tire. Oh and the front fenders come rolled from the factory so the only modification you can do to the front fenders are "pull them"
Old Apr 13, 2014 | 09:05 PM
  #23291
rsoto20's Avatar
rsoto20
Old Apr 15, 2014 | 12:18 PM
  #23292
driftsucky's Avatar
driftsucky
CLEARLY this guy gets it.
Old Apr 15, 2014 | 04:30 PM
  #23293
KingBaby's Avatar
KingBaby
Hardest Setting
bitter beer face at post #23290
Old Apr 16, 2014 | 06:25 PM
  #23294
NuGen Auto's Avatar
NuGen Auto
Vendor - Former Vendor
If any of you guys are looking for some coils or wheels let us know. Please feel free to pm us. We could help with the aggressive wheels and getting that thing low.
@Potato hit us up for some wheels brother! That thing would look sweet!
Old Apr 16, 2014 | 08:21 PM
  #23295
5150_91's Avatar
5150_91
Still working on the rear clearance. Installed Cusco front upper arms.
Old Apr 16, 2014 | 09:06 PM
  #23296
fataLblitz's Avatar
fataLblitz
Not as aggressive as others, but running 0 camber has its perks
Old Apr 17, 2014 | 03:25 AM
  #23297
NuGen Auto's Avatar
NuGen Auto
Now this looks great! A job well done sir!
Old Apr 17, 2014 | 03:13 PM
  #23298
PCH's Avatar
PCH
Got my car back from paint a couple of weeks ago, here are some updated pics -
Old Apr 17, 2014 | 04:32 PM
  #23299
KingBaby's Avatar
KingBaby
Hardest Setting
Looks great!
Old Apr 17, 2014 | 06:17 PM
  #23300
mr. sparco's Avatar
mr. sparco
Freshly painted/detailed black cars look so damn clean.
