Aggressive Wheels and Stretched Tires....Welcome
Old Feb 19, 2011 | 08:55 PM
  #14101
KingBaby's Avatar
KingBaby
Hardest Setting
haven't coated it yet...
Old Feb 19, 2011 | 09:08 PM
  #14102
young Jee(Z)'s Avatar
young Jee(Z)
just lost ALL structural integrity that the fender had, any small "rub" now will result in a buckled fender skin.
i get the idea, but not exactly how i would have went about it.
edit: looking back at it, it actually might workout well. i give you credit regardless, close/weld/seal those cuts asap.
Old Feb 19, 2011 | 09:14 PM
  #14103
Max-G's Avatar
Max-G
jeez i don't think i'd go through that much effort. getting smaller tires would be easier. all i did was hammer the **** out of the liner and it cleared up enough space and keeps the strength of the fender. that just looks sketchy.
Old Feb 19, 2011 | 09:15 PM
  #14104
darkzschneider's Avatar
darkzschneider
Yeah You wont loose any outer fender structure.
I cut all mine out and rolled and pulled and it came out prefect.
Just to give you guys an inside view of under the fender here you go..
This is my car I cut out all the rubbing parts. I put on entire new rear quarters.
Old Feb 19, 2011 | 09:54 PM
  #14105
KingBaby's Avatar
KingBaby
Hardest Setting
I'm not running skinny tires...
It won't buckle and I just got back from pushing the **** out of her...
It took me two hours before I even touched the car due to all those issues...
Works...
Old Feb 20, 2011 | 07:47 AM
  #14106
350DAN's Avatar
350DAN
Works...
cuts came out good king! any rubbing issues now?
Old Feb 20, 2011 | 09:06 AM
  #14107
KingBaby's Avatar
KingBaby
Hardest Setting
well I use to rub on dips as most of us here...
I took her to places where my butt-hole would clinch up...
everything seems normal no *brum*ba*/ *pigs squealing* noise
BUT
and I knew you guys are waiting for the bad
it rained last night and the car sounds like a shower is in the trunk...
gonna spray that rubber coated and hopes that keeps the road noise back to normal...
Old Feb 20, 2011 | 10:56 AM
  #14108
KingBaby's Avatar
KingBaby
Hardest Setting
also
do not attempt...
if you do try to...measure out a piece inbetween me and 350DAN...
his was too little for my taste...and my cut is more than what's needed...
so in the middle is just right...
a little red riding hood look at the situation...
again do not attempt take it to a shop and spend your money...
Old Feb 20, 2011 | 11:03 AM
  #14109
GenX350z's Avatar
GenX350z
finally got he VS KF's mounted...
but then i run into this problem....
any suggestions? camber is at -3.8 right now.
Old Feb 20, 2011 | 11:06 AM
  #14110
Adon's Avatar
Adon
^ damn i know one thing for sure, you won't be able to wipe off or get rid of that yellowish brown hazing, happened from the heat of the rubbing, i just got the same thing the other week and havent been able to get it out with any product, even tried wetsanding it out, **** is literally baked into the paintwork
i had to raise the car back up no other option, at least until i get my fenders pulled out half an inch, camber is at -4.5 and i dont rub anymore.
from the looks of it as well why not add more poke up front, you got a flush setup front and poke out rear
Old Feb 20, 2011 | 11:07 AM
  #14111
brandon3434's Avatar
brandon3434
MOAR camber, dogg...
Old Feb 20, 2011 | 11:11 AM
  #14112
KingBaby's Avatar
KingBaby
Hardest Setting
phonebook pull/flare using car magzines
will work...
your paint is fudged...
what's the specs on that rim?
Old Feb 20, 2011 | 11:17 AM
  #14113
GenX350z's Avatar
GenX350z
yes im pretty sure the paint is f**ked. but im not worried about that, just need these wheels to fit. been wanting to drive my car but thats what stopping me. the specs are 18x9.5 +1 and 18x11.5 -23
Old Feb 20, 2011 | 12:05 PM
  #14114
KingBaby's Avatar
KingBaby
Hardest Setting
jack the car up and flare it...
take it to a shop and have them do it...
Old Feb 20, 2011 | 01:04 PM
  #14115
350DAN's Avatar
350DAN
more camber and a massive pull...if you dont have a fender roller on hand jack up the car, put a heat gun to the fender and use the phone book to flare the edges out
Old Feb 20, 2011 | 01:49 PM
  #14116
SuperBlack350z's Avatar
SuperBlack350z
thanks to Toby22 for taking these teaser pics. no close up of the wheels until after i cleaned them thoroughly with the car.
Old Feb 20, 2011 | 02:08 PM
  #14117
lixam's Avatar
lixam
space it out/more low.
Old Feb 20, 2011 | 02:09 PM
  #14118
lixam's Avatar
lixam
teaser pics for ......???
Old Feb 20, 2011 | 02:13 PM
  #14119
SuperBlack350z
cant say. i don't want people to copy should be done soon though hopefully now that the weather is warmer.with my tax check and a bit of what i have saved up, a single turbo is not a bad idea.
Old Feb 20, 2011 | 02:15 PM
  #14120
Toby-22's Avatar
Toby-22
damn andrew you suck when it comes to picking pics...let me help you out
