Pressure monitor question..
Old Jun 4, 2003 | 05:01 PM
slay2k's Avatar
slay2k
Question Pressure monitor question..
I've got a perf. model, with non-Rays.
Just put on 18" Rays which are supposed to have the monitors in them. After driving for 20-30 min, the computer shows "--" as if it doesn't get a reading.
Might I need to disconnect the battery or some BS like that ? Or is it possible that the monitors are simply missing ?
-slay
Old Jun 4, 2003 | 05:02 PM
2003z's Avatar
2003z
I'm not positive, but I think you need the dealer to calibrate them.
Old Jun 4, 2003 | 05:08 PM
slay2k's Avatar
slay2k
Ahh I thought that may be it..
Can anyone else confirm that ?
Thanks!
Old Jun 4, 2003 | 05:25 PM
MannishBoy's Avatar
MannishBoy
Looking at the shop manual, you seem to have to have at least a Consult II, and preferably a Consult II combined with a transmitter activation tool to register the sensor IDs.
Old Jun 4, 2003 | 06:13 PM
slay2k's Avatar
slay2k
So it's confirmed then, dealer's gotta do it ?
Old Jun 4, 2003 | 06:47 PM
BZNYA's Avatar
BZNYA
Confirmed. When I spoke to a Nissan tech they said I may have to re-calibrate mine when I installed them to another wheel. Looks like I'll have to do it as only two are registering, one front, and one rear....
Old Jun 4, 2003 | 07:05 PM
slay2k's Avatar
slay2k
Warranty ? Or you gotta pay for this ?
Old Jun 5, 2003 | 12:14 AM
SirZaLot's Avatar
SirZaLot
Maybe the one who sold you the Rays took out the monitors.
Old Jun 5, 2003 | 12:38 AM
ares's Avatar
ares
Veteran
ummm Im not totally following, you have performance, so where your sensors go? you should use them...
I took mine out of my tires, put them in my new tires, and they worked, it wasnt done at the dealer, and I was the first person to drive the car when they finished, so I know that no adjustments were done. just worked as tho nothing changed.
somethin isnt right with your setup, either they arent your sensors(which then you might need them to be calibrated to recognize the new sensors) or there are no sensors in them for some reason.
Old Jun 5, 2003 | 07:43 AM
viny1200's Avatar
viny1200
I had the tire shop install the stock sensors on my new wheels and no adjustments or programming was needed. All four work fine.
slay2k - If you didn't have the stock sensors in your old wheels, or if the new wheels have someone else's sensors, I would think a trip to the dealer would be in order (your dime ) if you're sure the sensors are there.
BZNYA - you seem to have a different problem as it sounds as though you are using your stock sensors. If two are working, and two are not, it may be an installation problem.
Old Jun 5, 2003 | 09:06 AM
failsafe's Avatar
failsafe
....for your health
Ditto- pulled the sensors out of my stock wheel and mounted them in my Volk's- no problems whatsoever.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
Vigman
Nov 17, 2015 04:34 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
