Steering got lighter with front tire replacement
Old Dec 27, 2007 | 06:47 AM
GalvatronType_R's Avatar
GalvatronType_R
Default Steering got lighter with front tire replacement
Already searched...
After getting nails in both front tires, I decided to buy a new pair. After getting them installed and getting alignment, the steering feels much, much lighter. I know that tires have a break in period so I'm guessing that after they're broken in, the steering will get back to its previous heavier feel (I prefer that heavier feel). Also, I checked the steering fluid and it's at the proper level.
So if anyone has a different opinion or knows for sure I'm wrong and that my front axle will fall off, please let me know.
Old Dec 27, 2007 | 07:17 AM
Escobar's Avatar
Escobar
I know what you mean. I put my stock wheels/tires back on for a few days and the steering felt much lighter and it turned a bit quicker.
Old Dec 27, 2007 | 07:36 AM
HondaKiller's Avatar
HondaKiller
different air pressure in the tires could cause something like this. 45psi and 35psi makes a world of difference.
Old Dec 27, 2007 | 07:43 AM
Escobar's Avatar
Escobar
yeah thats definately true, did you put the same exact tires back on?
Old Dec 27, 2007 | 07:46 AM
NickRaine78's Avatar
NickRaine78
Maybe they didnt use air!
Old Dec 27, 2007 | 07:53 AM
driftk1d's Avatar
driftk1d
i myself fill my tires with water to get that smooth flow
Old Dec 27, 2007 | 08:27 AM
GalvatronType_R
Yes, bought the same exact tires to match the un-nailed rears and used the same exact pressure (35 psi, factory spec).
After reading Tire Rack, they said that tires are lubed to separate them from the mold so some of that excess lubrication may still be present on new tires. The mold lube should wear off as the tires break in. I'm hoping this happens soon so I can get back to the previous steering feel.
Old Dec 27, 2007 | 09:16 AM
NickRaine78
Helium for me....I like the feeling of floating while driving.
Old Dec 27, 2007 | 09:20 AM
Nexx's Avatar
Nexx
+1, my steering felt sluggish the other day so i checked my tire pressure. due to the weather change my tires had slowly dropped to 25psi, inflated them back to 35psi and the steering was felt lighter before the pressure drop.
Old Dec 27, 2007 | 09:34 AM
New tires will definitely alter steering feel. Lighter, heavier, skittish, whatever. In a few thousand miles you will be accustomed to the tires and say “Gosh these feel just like my old tires.”
Old Dec 27, 2007 | 09:58 AM
Manu's Avatar
Manu
Since new tires have more thread depth, there is more flexing from the rubber blocks on the tire than you are used to. If your punctured tires were new as well, I'd think you have over inflated tires.
bcoffee20
Nov 19, 2015 06:39 PM
Paul.
Oct 16, 2015 07:34 PM
emooheo
Oct 14, 2015 08:58 AM
Mw870
Sep 10, 2015 07:50 PM
Beater350z
Sep 9, 2015 03:36 PM
