Unofficial Enkei Wheels Thread
Old Feb 25, 2016 | 03:10 AM
  #2501
Pengu's Avatar
Pengu
Default Questions about Enkei RPF1's
Hello all!
I asked if another thread but didn't get a response and did a quick google search but did not get anything. So hopefully I do not get flammed.
I am picking up Enkei RPF1 18x9.5 and 18x10.5 +15 all around this weekend. I have two questions about this:
Can I use OEM lugs with this for a couple weeks? This might be a stupid question but I want to be 100% sure I won't have any issues with this.
My second question is for recommendations on hub adapters.
Is this something I would be looking for?
Amazon.com: AccuWheel ACHR73-6606M Aluminum Wheel Hub Centric Rings (73.00mm OD to 66.06mm ID) - Pack of 4 Hubrings: Automotive Amazon.com: AccuWheel ACHR73-6606M Aluminum Wheel Hub Centric Rings (73.00mm OD to 66.06mm ID) - Pack of 4 Hubrings: Automotive
Old Feb 25, 2016 | 03:35 AM
  #2502
jhc's Avatar
jhc
General & Tech Moderator
Originally Posted by Pengu
Hello all!
That is my spec. You will love them!
The oem acorns will not fit. No hub adapter necessary, plug and play. Enjoy!
Old Feb 25, 2016 | 03:51 AM
  #2503
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
JHC is a bad boy and doesn't play by the rules. While hubcentric rings aren't necessary, they will help eliminate any vibrations from off-balance wheel mounting. Here are the specs you will need:
http://www.ebay.com/itm/4-Aluminum-H...pT7iVm&vxp=mtr
Old Feb 25, 2016 | 03:58 AM
  #2504
Pengu's Avatar
Pengu
Dang, I'll have to order lugnuts then before I can put them on . Should I be looking at anything in particular with lugnuts? I am a wheel newb.
Also thank you Advan I'm going to order those right now.
Old Feb 25, 2016 | 04:00 AM
  #2505
Z1NONLY's Avatar
Z1NONLY
I use hub-centric rings on my RPF1's. The wheels will mount without them, but the studs will have extra forces to deal with.
With the rings, the studs only have to hold the wheel flush against the hub. All other force is on the hub itself.
My rings came from Tire rack and are basically plastic. I think I may try a set of those aluminum ones though.
Old Feb 25, 2016 | 04:01 AM
  #2506
AdvanZ33's Avatar
AdvanZ33
You will definitely appreciate tuner lugs with a thin-wall adapter (Muteki, Gorilla, etc) or you will be constantly rubbing the paint from your lug holes.
Old Feb 25, 2016 | 04:03 AM
  #2507
Z1NONLY's Avatar
Z1NONLY
Enkei lists the bore at 73mm, not 73.1mm?
  #2508
AdvanZ33's Avatar
AdvanZ33
I've went aluminum and never looked back. They last forever and if they fall off you actually hear them hit the ground.
Old Feb 25, 2016 | 04:08 AM
  #2509
Pengu's Avatar
Pengu
I just noticed that on the link Advan posted was 73.1 I believe the ones on Amazon that I linked were 73mm. Any input?
Old Feb 25, 2016 | 04:09 AM
  #2510
Z1NONLY's Avatar
Z1NONLY
I change wheels evry month for the track and the plastic rings are a PITA to remove (without breaking) when the hubs are still warm.
My SSR's use aluminum rings and are easier to work with.
Old Feb 25, 2016 | 04:12 AM
  #2511
Z1NONLY's Avatar
Z1NONLY
I don't know the specs on my rings because Tire Rack just said "We have the rings for those wheels and will send you a set".
Old Feb 25, 2016 | 04:15 AM
  #2512
AdvanZ33's Avatar
AdvanZ33
My bad, I thought they sold rings as 73mm/73.1mm, not both. I would definitely go with 73mm since that's what the website says. I will edit my post above.
Old Feb 25, 2016 | 04:21 AM
  #2513
Pengu's Avatar
Pengu
It's okay, I know it is your ebay store and you were just trying to get my money.
Old Feb 25, 2016 | 04:26 AM
  #2514
Pengu's Avatar
Pengu
Thanks for the input everyone, below is what I'm ordering.
Lugs -
Amazon.com: Muteki 32905L SR Series Purple 12mm x 1.25mm SR48 Open End Lug Nut Set, (Set of 20): Automotive Amazon.com: Muteki 32905L SR Series Purple 12mm x 1.25mm SR48 Open End Lug Nut Set, (Set of 20): Automotive
Hub Ring Adapters -
Old Feb 25, 2016 | 06:18 AM
  #2515
jhc's Avatar
jhc
ThanQ, I sit corrected.
Old Feb 25, 2016 | 10:03 AM
  #2516
terrasmak's Avatar
I wonder if there is any information about RPF1 over here ?
https://my350z.com/forum/wheels-and-...ls-thread.html
Old Feb 25, 2016 | 05:22 PM
  #2517
superlim9's Avatar
superlim9
Originally Posted by Bak3rme
hey u are brian's friend right? i was with u guys on kanc cruise
Im part of NEVQ, but havent made on the KANC cruise yet... always at work.
Old Feb 25, 2016 | 05:37 PM
  #2518
superlim9's Avatar
superlim9
Might be missing a better thread to ask, but this is as good as I can find currently. I am picking up Enkei 18x9.5 18x10.5 +15 all around this weekend. Can I use the OEM lugnuts for a few weeks? Also, I'm already ordering the hub adapters so I'll have those before putting the wheels on.
Thanks!
Hub Adapters?
Old Feb 25, 2016 | 06:10 PM
  #2519
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Originally Posted by superlim9
Hub Adapters?
I was also reading that like why wouldn't you be getting the wheels with the correct lug pattern...
But I think by hub adapter he is talking about is the little plastic ring that goes over the hubsentric ring so their is no play around the hub...
I could be completely wrong though.
Old Feb 26, 2016 | 04:15 PM
  #2520
GPD's Avatar
GPD
Got my rims! They are 18x9.5 with +15mm offset. Here's some before and afters.
That is my Duramax in the background. It got new Michelin Defender LTX M/S all around. Today was an expensive day, lol.
They are very flush. No spacers. 275/40 on rear, and 255/40 on front.
The rims and tires, lugs, mounting and balancing and all that stuff came out to just under $2300.00. Not bad for some much needed traction, and a way more aggressive look. The old tires and rims looked like they belonged on a Prius or something.
