With the +13 in the front(with the spacer) did you have to get it realigned? I've been thinking about putting a 5mm spacer in the front to go +10 but I'm worried about rubbing in the front a little...
To my understanding, spacers do not affect your alignment.
On what wheel width? You could always try it and see.
On mine I am about ~1.2" lower in the front with 18x9 +15 with a 265/35 and no rubbage..........even under very hard cornering. My car is almost exclusively used for autox and track days now though.....so the alignment is pretty aggressive.
What did you decide on for alignment and wheel studs (you probably told me already, and if so, I've forgotten - sorry!)
Just billet spacers w/ ARP studs. I run about -2.7 camber on the front now w/ 1/16" toe-out....caster is 9. Rear is only -2.1 (stock vlsd..............sigh) w/ 1/16" toe-in
please wxcuse my noobyness . . but im about to purchase wheels for my Z and am under the impression that rpfs are the lightest enkeis that once can buy . . . is that true ?
Yes the RPF1's are really light but i think the PF01's are now the lightest
18x10.5 RPF1 +15: 19.7#
18x10.0 RPF1 +38: 19.1#
18x10.5 PF01 +15: Could not find (but likely higher than 21.8# given the 18x9.5 PF01 data)
18x10.5 PF01 +38: 21.8#
At the end of the day, it appears these are a heavier version of Enkei's race wheel. Here is additional comparison from what they did publish from their engineering data (of the PF01):
After a long wait I finally had them put on. Pics were taken last night so there not the best but more will come after the weekend (front needs to be lower). Wheels are courtesy of Oakos Automotive, awesome customer service!!
Specs 18/9.5 +15 Sumitomo HTRZ III 245/40, 18/10.5 +15 275/40
