Unofficial Enkei Wheels Thread
Old Aug 15, 2013 | 06:15 AM
  #1841
Bmurray350z's Avatar
Bmurray350z
what camber are you at in the front? my fronts have a skinnier tire (245/35/19) and i am about the same height, and it rubs like **** even with my coilovers set at full stiff!
Old Aug 15, 2013 | 06:25 AM
  #1842
RENFRO's Avatar
RENFRO
-1.8 in the front, -2.2 in the rear.
Old Aug 15, 2013 | 06:26 AM
  #1843
Bmurray350z
yeah i'm at -1.6 front. weird.
Old Aug 15, 2013 | 06:33 AM
  #1844
RENFRO's Avatar
RENFRO
Could be the shape of the tire maybe? The only noise I ever get in the front is from my SPL arms over bumps. Normal little clunk noise, but definitely no rubbing.
Old Aug 15, 2013 | 06:39 AM
  #1845
2004Black350z's Avatar
2004Black350z
Exhaust Whore
I run a 5mm out back with the same size tires and -2.2 camber. If you straighten your camber out a bit, you will get more poke.
Thanks terras. Next step is raise slightly still think 10mm plus realign and around -2 degrees. Would you buy extended studs for 10mm?
Old Aug 15, 2013 | 06:58 AM
  #1846
terrasmak's Avatar
You have to, without extended studs you will have about 1 thread. ARP studs look great with RPF1's
Old Aug 15, 2013 | 07:13 AM
  #1847
Bmurray350z
Z1 Motorsports claims you can run up to a 10mm slip on with stock studs.. but i wouldnt trust it.
Old Aug 15, 2013 | 08:07 AM
  #1848
2004Black350z
Exhaust Whore
Good info thx. My to do list is getting outrageous lol
Old Aug 15, 2013 | 09:04 AM
  #1849
terrasmak's Avatar
I tried it a long time ago just for fitment reason. Bolted it up and rolled the car 5 feet to settle the suspension. Had to leave them loose, then i tried to torque them the threads were removed from a lug nut.
Old Aug 15, 2013 | 09:21 AM
  #1850
mr. sparco's Avatar
mr. sparco
5mm or less is considered safe, but even then I had to re-thread. Lugs are a wear and tear item and should be replaced especially if the wheel is taken off repeatedly with an air gun.
Old Aug 16, 2013 | 05:35 AM
  #1851
vtchang's Avatar
vtchang
18x9.5+27 over 355" ST60 STR
Old Aug 16, 2013 | 01:17 PM
  #1852
mr. sparco's Avatar
mr. sparco
Nasty, after you clean the wheels and install tires, it'll look perfect.
Old Aug 16, 2013 | 05:20 PM
  #1853
deadohiosky1984's Avatar
deadohiosky1984
Default Tire fitment question... Will it rub? RPF1 & RS3's
I just picked up some RPF1's 18X9.5 +15 for my base 2004 350Z.It sits at stock height with bone stock suspension. I track the car occasionally and am going to an auto X event in September. This is my DD as well.
I was wondering if anyone has had any fitment issues or rubbing with 265/35R18 Hankook RS3 tires. I was debating getting 245 size tires in the BFG Rival to be sure that I would have no fitment issues but, from what I've seen, that's a bit on the small side and I would rather have the wider tire if I could.
I've done some searching on the topic and have not found a conclusive answer from someone with this exact setup so any input is apprecitaed.
Soooo... ***FLAME SUIT ON****
Old Aug 16, 2013 | 05:57 PM
  #1854
terrasmak's Avatar
They can rub up front slightly under full compression.
Old Aug 16, 2013 | 10:13 PM
  #1855
SE5spd's Avatar
SE5spd
My 265 on 9.5" didn't rub and my 275 on 9.5" don't rub not even under track conditions.
Old Aug 16, 2013 | 10:45 PM
  #1856
terrasmak's Avatar
WetdreamsZZ car rubbed slightly with that combo. We know all these cars seem o be slightly different.
Old Aug 17, 2013 | 07:03 AM
  #1857
David_2613's Avatar
David_2613
If it does rub, you can probably fix it without rolling your fender by removing the top fender lining bolt and bracket.
Does anyone see a problem with removing 1 or all 3 of these bolts and brackets? The fender lip seems to do a pretty good job of holding the liner without them.
Old Aug 17, 2013 | 07:10 AM
  #1858
terrasmak's Avatar
I just remove the screw, cut the screw down , reinstall and fold the tab slightly. I did that to the above mentioned car and hand pulled the front slightly.
Old Aug 17, 2013 | 09:43 AM
  #1859
SE5spd's Avatar
SE5spd
He's probably lower then I am but on the same token he has stiffer front springs.
Old Aug 17, 2013 | 03:53 PM
  #1860
deadohiosky1984
Thanks for the responses! I am getting the RS3's this coming week! Can't wait to run the auto x with them!
