Unofficial Enkei Wheels Thread
Old Jul 25, 2011 | 11:48 AM
  #981
scotts300's Avatar
scotts300
Originally Posted by ericjackson
i was told the wheels are +15. the spacer is not much. like 5mm or so. it just needed room for the inside of tires to clear. I need to take a look at the wheels when i take them off to be sure though since i just bought them and test fitted this weekend.
To clear what? If they are 9.5 +15, they should clear without a spacer. I run that size with a 285/35, as well as a 285 on 10.5 +15.
Old Jul 25, 2011 | 12:02 PM
  #982
ericjackson's Avatar
ericjackson
well im not sure, the guy i bought them from, said the fronts wouldnt clear the inside with the 285's so he gave me his spacers that he had to use. wish i would have known that before i installed longer studs this weekend...
Old Jul 25, 2011 | 12:08 PM
  #983
03threefiftyz's Avatar
03threefiftyz
It's all fun until you have to replace the 19" A6....the 18's are pricey enough!
Old Jul 25, 2011 | 12:22 PM
  #984
ericjackson
haha you arent lying. Luckily the rears only have 2 races on them. And i have 6 extra v710's for the front. All this wheels/tires for $600. I couldnt beat it.
Old Jul 26, 2011 | 10:34 AM
  #985
SE5spd's Avatar
SE5spd
Anyone know what the biggest you can stick on a 9.5 RPF1 is?
Old Jul 26, 2011 | 10:37 AM
  #986
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
You mean widest? Are you lowered? Offset? Front or rear?
Old Jul 26, 2011 | 11:09 AM
  #987
scotts300's Avatar
scotts300
Which offset are they? Regardless, 275/40/17 is the biggest I'd put on it
Old Jul 26, 2011 | 11:38 AM
  #988
Zazz93's Avatar
Zazz93
I've seen a guy track a 9.5 +20 with 285/30 on the front and 10.0 +22 with 295/30 in the rear on a Z, but I limit my 9.5's to 275's.
Old Jul 26, 2011 | 11:40 AM
  #989
03threefiftyz
265 would probably be best, but 275 would work too.
Old Jul 26, 2011 | 11:53 AM
  #990
Kirbaaybaayy's Avatar
Kirbaaybaayy
for tracking 265 would be better not to small or to wide
Old Jul 26, 2011 | 01:18 PM
  #991
scotts300's Avatar
scotts300
He is looking at 17" RPF1s.
I have only seen the Dunlop Star Spec in 265/40/17, which of course works. I ran 275/40/17s on 9s forever, then (wide Hoosier 275/40/17s) on 17x10 FN01R-Cs.
Old Jul 26, 2011 | 09:41 PM
  #992
SE5spd's Avatar
SE5spd
Oh I'm talking about my 18x9.5 +15 front
The 17x9.5 +18 ones I'm getting I'm putting 255/40/17 RS3s on cause they cost $125.00 a tire
Old Jul 27, 2011 | 06:35 AM
  #993
scotts300's Avatar
scotts300
Well don't you already have 265 RS3s on that 9.5 +15 front? You can fit larger (275 or 285), but the consensus is that the RS3s like a little stretch, so that 265 is perfect. Why would you change it up at this point?
Old Jul 27, 2011 | 07:55 AM
  #994
03threefiftyz
Agree, I would stick with the 265 on the 9.5" with the RS3's....even a 255.
Old Jul 27, 2011 | 08:38 AM
  #995
SE5spd's Avatar
SE5spd
I'm potentally just gonna sell my 18in RPF1s and buy the 17s and put some spacers back on. My friend I've been talking to wanted to know whether he could fit 275/285 combo or even just a 285 square on a 9.5/10.5.
I didn't know the answer so that's why I'm asking.
Old Jul 31, 2011 | 02:57 PM
  #996
flynbrin's Avatar
flynbrin
18X9.5 +15 with 15mm spacer= +0
18X10.5 +15 with 15mm spacer= +0
265/35/18 front
265/40/18 rear
Old Jul 31, 2011 | 03:02 PM
  #997
ChriZTT's Avatar
ChriZTT
Sweet set up! Thanks for the specs. Any idea what your alignment specs are? Thanks.
Old Aug 1, 2011 | 12:04 AM
  #998
flynbrin's Avatar
flynbrin
lowered on stance with stock alignment specs
hope that helps
Old Aug 1, 2011 | 02:07 PM
  #999
lazyduster's Avatar
lazyduster
Old Aug 1, 2011 | 06:36 PM
  #1000
Kirbaaybaayy
Originally Posted by lazyduster
mmmm more please!
