Unofficial Enkei Wheels Thread
ok, so I want to buy some Enkei Lusso w/ Mach Lip, but im not sure the offsets will fit my car. I have a 2007 350z, and the stock rims are 18x8 +30, 18x8.5 +33. The enkeis are 18x8 +40, 18x9 +40.
Will these fit w/o me rolling the fenders?
Do I need to do anything to the suspension? The nissan dealer said i might have to
Pass on those wheels, offsets are too weak. They are more than likely made for a fwd vehicle. Also the rims aren't even that wide, for the rear I'm fitting a 18x10.5 +15 et with a 275 and it fits just fine. If you get those the gap will be humongous without a massive spacer. No need to roll your fenders because they won't be anywhere near the fenders. Go with at least 9.5" inch rim all around with a 0 to +22 offset if you don't want to be that aggressive but you don't want a fender gap.
hahah no one told me to buy these rims. im judging rims by looks first, then what fits. of course, both are kinda needed
So the more positive the offset, the more the center face of the rim is closer to the outside of the car. The more negative the offset, the more the center face of the rim is closer to the inside of the car.
will a 9.5 inch rim fit my 225/245 setup? I see alot of 10 width on the rear in this forum, would that still fit 245?
say, whats the wtty like on most of these rims? If im paying close to a grand, i should expect lifetime. Im checking out konig, and they only have a year. thats pretty crappy
edit:
I like the cleanliness of the below pics, but i dont like how i cant find a weight on them anywhere. In fact, sites that sell these, the data table will list everything but the weight, just as a N/A. One dudes post i found says they are 25lb, but who knows?
TSW Zolder
18x8 +20
18x9.5 +20
Looking good on car!
edit:
TSW Zolder
18x8 +20
18x9.5 +20
I think you are trying to say warrenty. Don't know what the warrenty is but they will cover defects. $1k for wheels is nothing, that is not even enough to get something quality.
edit: crap i have 45s. is that a big difference?
Hey all, im on the fence about buying a set of wheels, enkei rpf01, but am not sure if the +30 in the front will clear my willwood bbk..... what do you guys think?? anyone with the wheels and the kit running it currently?? If not does anyone know how big of a spacer i would need??
I don't see +30 being a problem at all and no spacer would be needed.
Here is the post that you need to review (again):
https://my350z.com/forum/wheels-and-...el-thread.html
Just a question hopefully someone can answer for me, I was debating on gettin the nt03+m in 18x9.5 +27 front and 10.5 +30 rear what would be needed to run this on a 05 track? Spacers? Tire size? Car will be dropped on coilovers. Thanks.
-chris-
-chris-
Spacers if you feel the need, and depending on the look you want with the tire size you pic. Common tire combo's can include 245 or 255/40 front and 275/40 rear to 275/35 front and 295 or 305/35 rears.
Figured I'd go with a 245/40 front and 275/40 rear but I wasn't sure if the rims would fit with the brembos without the spacers. I would like to push it out a bit to make it sit flush but I don't really plan on going overboard. Thank you for the response.
-chris-
-chris-
Checkout member Kal_el's old setup for a nice setup with Brembos.
http://www.flickr.com/photos/61208532@N05/5636241480/[url=http://www.flickr.com/photos/61208532@N05/5636241480/]
I run 275/40 rear with 255/40 front, then a 20mm rear spacer and 10mm front spacer. For a daily driver i suggest a 15mm rear spacer so you do not need to run -2.1 rear camber. With a 15mm spacer out back you will be able to drop down to -1.8 and get better tire wear. The front will require about -1.5 to clear with a 255. In this pic i have close to -3, i would much rather daily drive on -1.5, you will get much better life out of your front tires.
Thanks for the info guys I really appreciate it. Still new to the z and trying to read thru threads still. Came from an evo and back there we just needed to keep outr tires square and rim sizes offsets ect same. Being I have a track model would running 255/40 and 275/40 for the rear be fine? I know almost everyone else is running 245/40 275/40 always thought the 245 would stretch a bit on a 9.5 rim so I was gonna see if 255 would be ok
