Unofficial Enkei Wheels Thread
Old Nov 3, 2011 | 03:49 PM
  #1081
SE5spd's Avatar
SE5spd
Originally Posted by JDSMotoring
PF01s on my track car
R888s?
what size are the tires? size/offset on wheels?
They clear BBK's and Brembo's very well.
[url=http://www.flickr.com/photos/61208532@N05/5636241480/]
I run 275/40 rear with 255/40 front, then a 20mm rear spacer and 10mm front spacer. For a daily driver i suggest a 15mm rear spacer so you do not need to run -2.1 rear camber. With a 15mm spacer out back you will be able to drop down to -1.8 and get better tire wear. The front will require about -1.5 to clear with a 255. In this pic i have close to -3, i would much rather daily drive on -1.5, you will get much better life out of your front tires.
are those 9.5/10.5?
what offset?
Old Nov 3, 2011 | 05:14 PM
  #1082
terrasmak's Avatar
Originally Posted by SE5spd
R888s?
are those 9.5/10.5?
what offset?
9.5 +27 front with a 10mm spacer making them +17
10.5 +30 rear with a 20mm spacer making it a +10
Old Nov 3, 2011 | 06:16 PM
  #1083
Random 350's Avatar
Random 350
Originally Posted by Rev_Night
So the more positive the offset, the more the center face of the rim is closer to the outside of the car. The more negative the offset, the more the center face of the rim is closer to the inside of the car.
will a 9.5 inch rim fit my 225/245 setup? I see alot of 10 width on the rear in this forum, would that still fit 245?
The lower offset the closer to the fender.
Since your not going for the flush look then the least you want to go for a 9.5" rim is 245. A 225 on a 9.5" rim will be stretched pretty good. Also a 245 on a 10" rim will be stretched pretty good as well.
I suggest going with:
18x9.5 +22 or somewhere close to that offset.
Then run 245 all around or throw some 265's on the back and 245 on front. It won't sit real close to the fender but it won't leave a huge gap.
Old Nov 4, 2011 | 04:49 AM
  #1084
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
R888s?
yes those are r888s 275 up front and 305 in the rear
wheels are 18x9.5 front and 10.5 in the rear +15 all around
Old Nov 4, 2011 | 09:08 AM
  #1085
Zoom750's Avatar
Zoom750
Originally Posted by chuckdashi
Just a question hopefully someone can answer for me, I was debating on gettin the nt03+m in 18x9.5 +27 front and 10.5 +30 rear what would be needed to run this on a 05 track? Spacers? Tire size? Car will be dropped on coilovers. Thanks.
-chris-
I have the exact same rims, which needed a 10mm spacer in the front to clear the OEM Brembos. With aftermarket BBKs, it seems no spacer is needed. This is on a G35. Tires are 275/35 front & 275/40 rear, but I'm not lowered.
Old Nov 6, 2011 | 08:25 PM
  #1086
shaddy-z.'s Avatar
shaddy-z.
Should I paint my RPF1's ? Right now they're silver as seen in the picture, I was wondering if I should paint them any color? My roof is painted black and my door handles are black but I want to hear your opinions.. I'm not sure if the wheels would look good black, because you can buy them that way and I want to be "different". I daily drive the car so I want a color that pops but nothing too rice. My only goal would be to paint them a different color, but not a color you could buy
them in if that makes sense.
Old Nov 7, 2011 | 02:23 AM
  #1087
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
White w/ extended red lugs and black valve stems.
Old Nov 7, 2011 | 11:05 AM
  #1088
shaddy-z.'s Avatar
shaddy-z.
If I do white I would want some sort of flake.. What color flake should I do?
Old Nov 8, 2011 | 08:45 PM
  #1089
Rev_Night's Avatar
Rev_Night
curious, i have OEM v2 tourings that weigh 24/25 lbs. Whats the conversion again for x pounds lost on rims, y pounds feel lost on frame?
Old Nov 14, 2011 | 09:58 AM
  #1090
Dragonbreath's Avatar
Dragonbreath
Thats ballin as hell! Honestly I wouldnt paint them anything. The silver on white looks super nice. I like silver wheels though. Gunmetal looks real good on a white Z.
Old Nov 18, 2011 | 08:11 AM
  #1091
ericjackson's Avatar
ericjackson
I am working on getting 2 more 19s for my PPW Z. These look like 18s.. I think they look great, but does anyone have 19" rpf1's on their PPW Z in bright silver?
thanks
Old Nov 18, 2011 | 01:14 PM
  #1092
shaddy-z.'s Avatar
shaddy-z.
Yeah they are 18. I'm running 18x10.5 all the way around..
Old Nov 18, 2011 | 05:43 PM
  #1093
ericjackson
yeah man they look great. i actually have a set of track wheels that are 18/f and 19/r. im just going to buy 2 more of each and have the 18's for track since 19in A6's are so expensive. i just really want to see a picture with 19s
btw, are you on coilovers?
Old Nov 19, 2011 | 01:21 PM
  #1094
shaddy-z.'s Avatar
shaddy-z.
Thanks a lot! And yes I am on coilovers.
Old Nov 21, 2011 | 07:31 AM
  #1095
BSERIEuS's Avatar
BSERIEuS
i can't seem to find the guy with the sunset orange Z running nt03's
but i do know he's running a square setup. my question is--will the 18x10.5 +30's have fitment issues up front? will a spacer be needed?
Old Nov 21, 2011 | 07:56 AM
  #1096
scotts300's Avatar
scotts300
Yes. My 18x10.5 +27 requires a spacer. I use 13mms of spacer, but I don't know what the minimum necessary is off hand.
Old Nov 21, 2011 | 09:17 AM
  #1097
BSERIEuS's Avatar
BSERIEuS
i thought that the 10.5s were only available in +30's and the 9.5's are +27 and up.
i definitely wanna pick up the 10.5's all around---and just want to make sure i pick up the right size spacers up front to clear the susp.
only reason why i wanna go with nt03's is b/c i ran rpf1's on my previous car. i want to change things up
Old Nov 21, 2011 | 09:20 AM
  #1098
SE5spd's Avatar
SE5spd
his username is Barnabas
"enkei nto3+m 18x10.5 +30 with 285/35/18 hankook RS3's all the way around
fronts currently have 5/16" spacers on them in order to clear front suspension. Plan is to go to +20 front +15 rear with spacers. Already in hand just need to put em on. "
post #570 on page 29.
Old Nov 21, 2011 | 10:22 AM
  #1099
scotts300's Avatar
scotts300
Different set of wheels, so it's a net 18x10.5 +14, similar to the RPF1 18x10.5 +15.
Old Nov 25, 2011 | 07:50 AM
  #1100
BSERIEuS's Avatar
BSERIEuS
thanks for the help Scott!
can't wait for christmas...finally buying wheels as a gift to myself. lol
