Unofficial Enkei Wheels Thread
I just ordered a set of used (3,000 miles, look new) RPF1s 18x9.5 on Ebay. I'm thinking about putting RS3s on the rims. My question is what sizes I should get for the back and for the rear? I have an 03 performance Z.
Could I still run a staggered setup even though I have the 9.5 on the front and back?
Any help would be appreciated.
265/40R or 275/40R
If you want to run RS3's you have a few options.
265/35 front 285/35 rear
265/35 front 275/35 rear
275/35 front 285/35 rear
265/35 square
275/35 square
285/35 square
I run a 9.5 and 10.5 RPF setup on my car with 275/35 front and 285/35 rear.
265/35 square
275/35 square
285/35 square
Difference in tire circumference is 1.08 percent. You drive a Performance to VDC? Read and study: https://my350z.com/forum/wheels-and-...read-here.html
You are in luck because Nissan has figured out all this stuff for you. Instead of a 19 inch wheel you have a 18 inch wheel. Increase the series by 5.
Yes I have a performance with VDC. So 245/40/18F and 265/40/18R will not present any problems? would 275/40/18R also work?
Have you read my post yet? If you want to run RS3's it is all you need to know.
It told me that the fronts have a 2.58% difference in diameter and the rears have a 3.12% difference to stock. Won't this cause problems for VDC?
Yes I looked at your post. I input your first suggestion of 265/35/18F and 285/35/18R into http://www.1010tires.com/TireSizeCal...?action=submit
The square combo's i suggest are the only ones that will/may give VDC problem when you don't have it turned off.
I have a VDC car, and i have posted what i'm currently running. I have also run 255-40-17 front and 275/40-17 rear, 275/40-17 front and rear (the only one that gave me problems), 275/40-17 front and 275/40-18, 275/35-18 front and 274/40-18 rear, all for track track setups. .
VDC wants to see a difference in speed between the front and rear tires. For all it cares you can run a 325/50-26 up front and a 345/50-26 out back, the difference in tire height between front and rear is what matters. Yes your speedo will be off slightly with the combo i suggest, but that is life.
So after reading this tread: https://my350z.com/forum/4339960-post2.html
Why did he have problems with VDC and why did the problem go away after he changed his tire from 4.4% to 0.4% of oem circumference?
I see the 285/35/18R is 3.1% different than the 245/45/18R that is stock on my Z. Will I have the same problem as he did?
OEM 225/45 F and 245/45 R combo the rear is +2.67% taller than the front.
---- 265/35 F and 285/35 R combo the rear is + 2.13% taller than the front
--------------- If you do the math, that would be a 0.54% veriation from stock. The computer will never know the difference.
