How do I remove the TPS from my wheels
Old Feb 26, 2008 | 04:16 PM
05Z33's Avatar
05Z33
Default How do I remove the TPS from my wheels
I am trying to remove the TPS from my stock wheels. How do I do this without breaking them. I tried doing a search but came up with nothing.
Old Feb 26, 2008 | 05:00 PM
350ZTheStandard's Avatar
350ZTheStandard
Local tire can do this for you, just let em know that they are in there & to be careful when removing. Why are you removing them, are you not a safety fan???
Old Feb 26, 2008 | 05:32 PM
ke0ki2k's Avatar
ke0ki2k
he likes to live on the edge !
EXTREME LIFE. he runs 4 PSI on the HIGHWAYYYYYY
puttin em on your next set of rollers?
Old Feb 26, 2008 | 06:02 PM
05Z33's Avatar
05Z33
I'm going to be selling them. I have aftermarket wheels on the car without the sensors, and the tps light dosen't bother me. I had a shop remove the tires but they did not want to remove the sensors for fear of damaging them.
Old Feb 26, 2008 | 06:52 PM
DavesZ#3's Avatar
DavesZ#3
Actually, removing the tires is when most shops damage the sensors. The sensors are mount through the valve stem. The shop is supposed to remove the nut on the stem and let the sensor fall into the tire, that way when they are dismounting the tire, it doesn't catch the sensor and break it away from the valve stem.
Old Feb 26, 2008 | 06:58 PM
QuicksilverZ33's Avatar
QuicksilverZ33
I work at a tire shop...if you are carefull you dont have to take the tpms off the rim to change a tire...you need a deep socket 12-14mm ( i cant remember) and a ratchet, you loosen the sleeve and it comes off(sleeve comes off the top, sensor falls through the inside of the rim.
Old Feb 26, 2008 | 07:00 PM
Spike100's Avatar
Spike100
I think it’s odd that a qualified tire shop would be fearful of removing TPMS sensors. It’s probably that they have no experience doing this, or they do not have the equipment to re-install and calibrate the sensors that spooks them away from this easy task.
--Spike
Old Feb 26, 2008 | 07:01 PM
Rowlett's Avatar
Rowlett
+1 easy work!
Old Feb 26, 2008 | 09:27 PM
finalforce's Avatar
finalforce
I had mine done at F1 Motorsports. They are awesome, they are very careful and they do flawless work on intallations.....well they only sell high end wheels (expensive) so they better be
Old Feb 27, 2008 | 04:27 PM
QuicksilverZ33
...its as easy as taking a lug nut off...as long as you have te tire off the rim already
Old Feb 27, 2008 | 06:27 PM
05Z33's Avatar
05Z33
thanks for the advise. I did not want to attempt this for the first time without makeing sure first.
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
