FYI: Project Kics Spacers - Napa Replacement Studs
Old Mar 18, 2008 | 09:00 AM
JasonZ-YA's Avatar
JasonZ-YA
Default FYI: Project Kics Spacers - Napa Replacement Studs
Hi,
I have project kic spacers and have already broken 2 studs. I just thought i would post the replacement studs i found to help the my350z community.
I found a NAPA and Autozone part number replacement studs that are holding up great so far.
The Z OEM studs are M12X1.25 with a 14mm knurl at the head
FRONT OR REAR: M12X1.25x42 (42 mm length) OEM F/R replacement -
NAPA P/N 641-3210 $1.74 each
AUTOZONE - 610-378.1 98353.1 if i remember right, about $1.80 each
PROJECT KICS SPACER STUDS:25 MM SPACER: (Spacer with studs)
M12X1.25X46 (46mm length) NAPA P/N 641-2786 $2.67 each - notice its 4mm longer is all!!!!
longer length is due to stud being pressed into a 25 mm thick spacer and needing more "shank/thread" length.
Replacing the broken stud is quite easy with even a small hobby shop press.
Also, due to the PKic's aluminum spacer I am certain you can use a big enough vise and some muscle power.
Harbor freight sells a small 6 ton shop press for about $39.99.
This one is one of their bigger 6 ton's:
http://www.harborfreight.com/cpi/cta...temnumber=1666
A friend of mine just bought a smaller tonage one for only $39.99 the other day but i dont know the item number to that one. sorry........
Harbor freight: (ITEM 4711-7VGA - about $80 bucks - see pic)
**Im bumping the next two post so i can have edit capability to add pictures later.
- Jason
DFW PEEPS: I have the press and all to do this job - hit me up and we can knock it out if you guys need help with this. bring corona's! lol.
The following is to help trigger searches:
Wheel spacers, project kics spacers, wheel studs, Replacement studs, M12X1.25
M12X1.25X46, 46 mm length.
JasonZ-YA's Avatar
JasonZ-YA
Default Pics
Here Are Pics Of The Broken Stud Still In The Oem Lug Nut And The Napa Replacement Stud Listed Above.
- J
Attached Thumbnails FYI: Project Kics Spacers - Napa Replacement Studs-img_3939.jpg   FYI: Project Kics Spacers - Napa Replacement Studs-img_3940.jpg
Old Mar 18, 2008 | 09:01 AM
JasonZ-YA's Avatar
JasonZ-YA
Default HF press and Alternate options:
More Pics. Harbor frieght: (ITEM 4711-7VGA - about $80 bucks)
Alternate option #1:
With the pic shown, you are still essentially pressing the stud in from the head side..........see that? so essentially its like using a press.....of course this is quite hard, you need a vise to hold in place and obviously a large socket that fits inside the stud with out the stud bottoming out on the c clamp as it tightens up..
Alternate option #2:
Use a Vice only instead of a C clamp like Alternate option #1 - but its all about lining up well...
Alternate option #3:
Kinda like method 3 i talk about on post #10
which is STEP 11 of the thread:
https://my350z.com/forum/body-interi...e-of-pics.html
I must also like to add - this was brought up in the "official wheel spacer thread"
You can get away with out using a "press" if you do the "6 ~ each washer/pull through" method.
Thats not the proper and intended way to do the job.....ie - pressing in from the head side with a press is the "correct" way....
The way you can also do it -- "WASHER/PULL THROUGH" method, you are pulling the stud through the spacer using a few Washers from home depot/lowes, etc and with a sacrificial nut, you simply tighten the nut pulling the stud through......
HOWEVER:
This method is putting a lot of stress on the stud "threads".......you could pull/damage the threads when tightening it up that much....sometimes its just one thread thats cracks at the thread valley groove, and you don't know it till the next time you do a wheel change and you find that that "Replaced" stud gets cross threaded or something..
HOWEVER/also....when replacing a stud using the "WASHER/PULL THROUGH" method in a SPACER you can get lucky doing it that way since the spacer itself is softer ALUMINUM and the splines from the stud neck most likely line up or match from the previous stud lines/neck that was originally in the spacer........
So if i was to do the washers/pull through method i would do it on a spacer if i had to over a hub anyday......so you may be fine... just be mindful of which studs you replaced as time goes on......and keep an eye on it...
-J
Attached Thumbnails FYI: Project Kics Spacers - Napa Replacement Studs-img_3945.jpg   FYI: Project Kics Spacers - Napa Replacement Studs-4711-7vga.gif
File Type: jpg
Old Mar 18, 2008 | 10:57 AM
noodleman's Avatar
noodleman
just a question, but how did you break the studs? over torqued them?
Old Mar 18, 2008 | 11:19 AM
JasonZ-YA's Avatar
JasonZ-YA
i believe so, it was the tire shop that changed my tires out for me... they used the air impact to install them.
a bit later i go to take them off and the lug nuts free up then after a few turns they get tight again???? i kept going with it and got a few really hard turns out of it and then snap!
- Jason
Old Mar 18, 2008 | 11:24 AM
THE_SCHROED's Avatar
THE_SCHROED
I need a replacement stud for a Ichiba 20mm spacer. I went to napa and advanced and they couldn't help me out. Anyone know where I can get one?
Old Mar 18, 2008 | 12:07 PM
JasonZ-YA's Avatar
JasonZ-YA
U need to take the broken stud out of the spacer! using a vise or a press and then go back to NAPA and have them look one up for you!
start with the part numbers i gave on post 1. take the entire spacer with you because you are going to want to measure the length of a non-broken stud.
- J
Old Mar 18, 2008 | 12:24 PM
THE_SCHROED
I have the kind of spacer that comes with the studs not pressed. I'm gonna try auto zone cause napa didn't have the right size.
Old Mar 18, 2008 | 02:13 PM
DustinZ33's Avatar
DustinZ33
I don't have personal experience but I do know someone that has. Beware of the replacement studs. He's had a few of them break.
Old Mar 18, 2008 | 02:38 PM
Triple8Sol's Avatar
Triple8Sol
I don't own KICS spacers, but this is great info. Thanks for sharing!
Old Mar 18, 2008 | 03:32 PM
SIN3's Avatar
SIN3
bump good info, thanks for taking the time for the write up.
Old Mar 18, 2008 | 06:47 PM
Ruthless18x's Avatar
Ruthless18x
Yeah that definitely could come in handy.
Old Mar 18, 2008 | 09:07 PM
SponGer's Avatar
SponGer
Subscribing in case I need the part numbers. Thanks man.
Old Mar 18, 2008 | 09:32 PM
JasonZ-YA's Avatar
JasonZ-YA
yup...i did a search and didnt find anything so after i did the leg work i figured i would post and give a data point on the subject.
-j
Old Mar 19, 2008 | 07:41 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Good info, thanks for sharing.
Old Mar 19, 2008 | 09:00 AM
JSia's Avatar
JSia
i cant remove the broken stud out of the spacer help =[
Old Mar 19, 2008 | 09:31 AM
JasonZ-YA's Avatar
JasonZ-YA
go to your local autorepair shop, a mom and pop shop and take them your spacer and have them remove your stud with a shop press. They shouldnt charge you any more than 8 bucks to do something like that!
A local tire shop also might have a shop press.
where in TX are you???
Harbor frieght sells shop presses: (ITEM 4711-7VGA - about $80 bucks - see pic)
This one is one of their bigger 6 ton's. A friend of mine just bought a small 6ton for only $39.99 the other day but i dont know the item number to that one. sorry........
like i said, ive done it before with a Big Vise and some muscle power too...
- Jason
Attached Thumbnails FYI: Project Kics Spacers - Napa Replacement Studs-4711-7vga.gif
Old Sep 2, 2008 | 01:13 PM
lgear080's Avatar
lgear080
jason - YOU'RE THE MAN.
Mostly bc I can't search on my own and have to ask
questions which smart people like you answered 6
months ago. Thanks for your help.
Old Sep 3, 2008 | 06:30 AM
JasonZ-YA's Avatar
JasonZ-YA
ha..no problem....
i too went through the pain of having to figure this junk out.....so i share...lol
-j
Old Sep 5, 2008 | 10:13 AM
trodis's Avatar
trodis
(subscribing)
