Will These Work on My ZR?
Old Mar 21, 2008 | 11:40 AM
DLH's Avatar
DLH
Default Will These Work on My ZR?
Looking at a set of Enkei,
they have them in 18 inch x 7.5 with a offset in 35mm & 45mm ,
Will this work with my BREMBO brakes?
They say it will......
which do I go 35 front or 45 back or which ???
Old Mar 21, 2008 | 11:42 AM
iStan's Avatar
iStan
ZR
7.5 is kinda thin. Those offsets are pretty bad. You would have to run atleast a 25mm/30mm spacer on the +35.. And I have no idea if it will even clear the brembos, but I believe it will because of how far the wheel is away from the hub at this point.
Old Mar 21, 2008 | 11:46 AM
DLH's Avatar
DLH
What offset's should I be looking for??
Old Mar 21, 2008 | 11:50 AM
iStan's Avatar
iStan
ZR
Depends on the width of the wheel and your preference for aggressiveness. Look around at pics and find something you like. It will more often than not be A correct size for the Z. Those Enkeis, I say no. Other Enkeis, I say HELL YES.
Oh, and no need for multiple threads. You have one in 350ZRoadster forum too.
My350P's Avatar
My350P
Around +20 is pretty common, but then you don't really see anyone running anything less than 8" wide.
Old Mar 21, 2008 | 01:41 PM
If you remove the brake callipers and struts they will be just fine.
Old Mar 21, 2008 | 01:43 PM
DBTRACK's Avatar
DBTRACK
Old Mar 21, 2008 | 04:52 PM
Triple8Sol's Avatar
Triple8Sol
Way too thin and terrible offsets. Not even close.
Old Mar 21, 2008 | 04:57 PM
plumpzz's Avatar
plumpzz
go for something closer to 8.5 or 9 inches with around a +30 or +25 ofsett..
Old Mar 23, 2008 | 01:03 PM
DLH's Avatar
DLH
19" Staggered Size: Two 19x8" (with +20mm offset) and Two 19x9.5" (with +35mm offset)
Will these be ok for my ZR with BREMBO guys???
Old Mar 23, 2008 | 02:05 PM
terrasmak's Avatar
Probably , but the rears you still want closer to +20
Old Mar 23, 2008 | 02:27 PM
xelaremnarc's Avatar
xelaremnarc
Yea, the +35 is still too high...
Old Mar 23, 2008 | 05:08 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Mar 24, 2008 | 01:23 AM
DLH's Avatar
DLH
What are the specs on my 2005 OEM 18 inch rims that are on the car now??
18 x ? offset?
Old Mar 24, 2008 | 01:26 AM
DLH's Avatar
DLH
18" Staggered Size, Two: 18x8" (20mm offset) and Two: 18x9" (20mm offset) Lug Pattern: 5x114.3mm to fit S14 240sx, 350z, G35 Coupe (including Brembo models)
Ok so These will work if im learning quick enough...?
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
