06 rear wheels on front
Old Mar 26, 2008 | 04:51 PM
MoJ's Avatar
MoJ
Default 06 rear wheels on front
Surely this has been covered before, sorry if it has but I didn't find what I was looking for...
Will the 06 rear wheels and tires work on the front without any problem? I was thinking of purchasing a pair of rear wheels with 245/45/18 to put on the front so I could fully rotate a set of non directional tires.
Thanks.
Old Mar 26, 2008 | 04:55 PM
TheProfessional's Avatar
TheProfessional
Will screw up your VDC/TCS and make your speedo read incorrectly... not to mention will look silly
Old Mar 26, 2008 | 05:05 PM
terrasmak's Avatar
Yes you can , but its not ideal.
Old Mar 26, 2008 | 06:34 PM
OMEGA46's Avatar
OMEGA46
what about rears on the front with just a wider tire, but same overall height?
Old Mar 26, 2008 | 06:58 PM
Swiffer's Avatar
Swiffer
That will work. VDC only cares about the overall diameter. It has no idea how wide the wheels are (or does it...........?? )
Old Mar 26, 2008 | 07:29 PM
z-u-later's Avatar
z-u-later
That's the ideal setup. Square setup . . . same size rims & tires on all four corners. Nothing to worry about -- it will not affect VDC.
Old Mar 26, 2008 | 08:44 PM
Why not?
Old Mar 27, 2008 | 04:28 AM
MoJ's Avatar
MoJ
Thanks everyone for the replies.
I hadn't considered it would be enough to cause VDC/TCS issues. As far as looks would it really even be noticeable if the rears matched? A friend did a similar set up on his M5 and I didn't notice it looking unusual.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Stevo Z
Oct 3, 2015 09:14 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
samansharif
Sep 25, 2015 12:31 PM
