Spacer question
Old Apr 17, 2008 | 06:44 PM
THe Emperor's Avatar
THe Emperor
Default Spacer question
If I used 15MM spacers on the rear wheels would I need to extend the studs or can I just use the exsiting OEM studs?
Old Apr 17, 2008 | 06:50 PM
THE_SCHROED's Avatar
THE_SCHROED
extended
Old Apr 17, 2008 | 06:57 PM
THe Emperor
If I get a set that has studs alreay built in I wouldn't have to romove the OEM studs right? I was looking at these by KICS. http://www.optionimports.com/kiwhsp5x1115.html
Old Apr 17, 2008 | 08:09 PM
THE_SCHROED
Yep, good spacers and Yeah don't have to replace stock studs.
Old Apr 17, 2008 | 08:23 PM
THe Emperor
OK thanks alot.
Old Apr 17, 2008 | 08:24 PM
THE_SCHROED
I think you might have to grind the studs down a little bit though. I put some 25mm on my car and it was a tight fit.
Old Apr 18, 2008 | 09:31 AM
BEbengali's Avatar
BEbengali
I believe some wheels have little spaces on the back of the mounting pad in between the drilled bolt holes, so the OEM studs would fit in there if the extend passed the spacer. There was a thread on here showing a guy with Enkei RPF1s that had no problems with the OEM studs sticking passed the spacers. I'm not sure how many aftermarket wheels have the little spaces on the mounting pad, though.
Old Apr 18, 2008 | 10:52 AM
Citrus's Avatar
Citrus
I've got the 15mm Project Kics spacers. The OEM studs stick out past the spacer, but the SSR's I'm running actually have another 5 holes for these type of spacers (part of the reason I went with the Project Kics spacers):
Old Apr 18, 2008 | 05:57 PM
THe Emperor
So what exactly happens if the OEM studs stick out through the spacers?
issyz
Jul 2, 2017 03:04 PM
