Handling difference b/t tires
Old May 26, 2008 | 10:45 AM
CKY881's Avatar
CKY881
Default Handling difference b/t tires
I'd like to know what the handling difference would be with a 255/40/18 front and 275/40/18 as opposed to 245/35/18 front and 275/35/18 rear on 18" Rota P45R. Also, would running lower profile mean less tread life compared to higher profile?
Thanks!
Old May 26, 2008 | 01:29 PM
Spike100's Avatar
Spike100
I doubt will will notice the handling between the sizes you mention since the difference is quite small.
Tire wear will be the same.
--Spike
The speedometer will read 104.31 MPH at 100.0 MPH.
Old May 26, 2008 | 02:15 PM
terrasmak's Avatar
the car will understeer more with the 245's in the front.
Old May 26, 2008 | 02:38 PM
Spike100's Avatar
Spike100
^^ That’s correct. Wider front tires on the Z provide less understeer. 10mm=3.9 inches, so the difference is small; but it’s probably slightly noticeable (or not, depending upon the tire).
As David mentions, a 35 aspect ratio to width on the OP’s second choice is less than the stock sidewall height, so there could be a problem with VDC or TCS (if the car is equipped with these features).
--Spike
Old May 26, 2008 | 05:37 PM
3fittyBiH's Avatar
3fittyBiH
i have 275/40/18 on the back, and its a huge difference. ride is sooo much smoother, and it def improves handling.
Old May 26, 2008 | 07:29 PM
Adrenaline Rush's Avatar
Adrenaline Rush
Faster acceleration, better steering response, and better braking with the 35 series tires. The 40's will have a smoother ride, more accurate speedometer reading, and will fill the fenders better.
Old May 26, 2008 | 08:03 PM
warmmilk's Avatar
warmmilk
Originally Posted by Spike100
^^ That’s correct. Wider front tires on the Z provide less understeer. 10mm=.39 inches, so the difference is small; but it’s probably slightly noticeable (or not, depending upon the tire).
--Spike
fixed
Old May 27, 2008 | 03:30 PM
Spike100's Avatar
Spike100
^^ Thanks. I keep doing that (misplaced decimal point).
--Spike
Old May 28, 2008 | 02:34 PM
CKY881's Avatar
CKY881
Is it uncommon for 18" to be using a 35 profile? All I've seen are 40 and 45's on 18. Is it bad to use 35 profile on 18"?
Old May 28, 2008 | 03:40 PM
Calvin@CRG's Avatar
Calvin@CRG
Temporary Disablement - Billing
ive ran 35s before and still do sometimes no difference in my opinion
Old May 28, 2008 | 04:39 PM
WheelDude.com's Avatar
WheelDude.com
Vendor - Former Vendor
I recommend a 255/40/18 front and 275/40/18 rear if those sizes are available in the tires you are looking at. 245/40/18 and 275/40/18 is still a great combo but the front tire will be slightly stretched on a 9.5 wide rim. I would not run a 35 series in the widths you listed as you will sacrifice ride quality and the speedometer will be off by about 3 mph.
The only time I recommend going to a 35 series on the 18x9.5 P45R's is if you want to run a wide tire. We run 265/35/18 front and 295/35/18 rear on our shop Z and it works well, you have to roll your rear fenders to fit this tire size though.
-Dan
Old May 28, 2008 | 07:25 PM
Spike100's Avatar
Spike100
^^ Very good post with excellent advice.
--Spike
Old Jun 3, 2008 | 01:19 AM
zBear's Avatar
zBear
-Dan
Did you notice less responsive handling when you went to the 265/35/18 Front and 295/35/18 Rear combination when compared to stock?
I just got my tire setup: 18in rims 9.5/10.5 with 265/35/18 Front and 285/35/18 Rear and if feels mushier than stock. They are stickier, but steering response and feedback is worse.
Old Jun 3, 2008 | 04:23 PM
Spike100's Avatar
Spike100
^^ What is your tire (brand and model)?
--Spike
Old Jun 3, 2008 | 05:58 PM
WheelDude.com
No we did not notice less response in the handling. What kind of tires did you get? It almost sounds like you were used to a stiffer sidewall and went with a tire that isn't performance oriented or has a softer sidewall. Also what tire pressure were you running on the stock wheels compared to your new setup?
-Dan
Old Jun 3, 2008 | 09:00 PM
zBear's Avatar
zBear
Stock setup:
Front Stock 225/45/18 Bridgestone RE50 35psi
Rear Stock 245/45/18 Bridgestone RE50 35psi
My current setup is:
Front TE37 9.5 +22 265/35/18 BFG KDW 35psi
Rear TE37 10.5 +22 285/35/18 Toyo T1R 35psi
These are high performance tires, but just not brand matched. I know I should get matching tires, but the KDWs and T1Rs are Brand New and came with the rims. If mismatched tires are the cause of my understeer or mushy steering, then I guess I'll have to find a set of T1Rs for the front.
Am I suppose to run the KDWs and T1Rs at a higher psi because of the smaller sidewall?
Old Jun 3, 2008 | 09:31 PM
Spike100's Avatar
Spike100
^^ You have the tire pressure right… it should be the recommended PSI for stock tires.
The problem might be a difference is sidewall rigidity between your front and rear tires. The Toyo’s have a softer sidewall than the BFG’s.
You said the tires are new, so that might be the problem. New high-performance tires are quite slippery for the first 100 miles or so (you really notice this), and then become much better.
I would run this setup a while longer to determine if it’s just the “greasy” layer on new high-performance tires causing the problem (and, I bet that is the problem). I think you will notice a significant improvement after a few days.
If it’s the sidewall flex, you probably will also be able to accommodate to this different handling. In fact it will begin to feel normal within a short time.
--Spike
Old Jun 8, 2008 | 10:34 PM
CKY881's Avatar
CKY881
-Dan
What's the negative thing about having stretched tires?
Old Jun 9, 2008 | 06:20 PM
Spike100's Avatar
Spike100
One downside of stretched tires: If you get anywhere close to a concrete curb, this piece of cement will try very hard to deeply gouge your expensive Volks. It happens a lot much to the dismay of people owning expensive wheels.
--Spike
350z82
Oct 1, 2015 06:25 PM
