Stock tires losing pressure
Old Jun 26, 2008 | 08:50 AM
tractng's Avatar
tractng
Default Stock tires losing pressure
Guys,
My stock 17 inch rear tires lose pressure after a week (even faster if I don't drive it). The thread looks good.
Any idea how I can troubleshoot it?
I am planning to take them off the car and visually check them. If I don't see any hole, I am going to drop it to a bucket of water.
Can the sensor /valve cause the leak or is a sign for me not to ride on the stocks any more (Sold my volks ).
Thanks,
Tony
Old Jun 26, 2008 | 08:58 AM
DavesZ#3's Avatar
DavesZ#3
Soapy water - squirt it around all the potential leaky areas - bead, valve, etc.
Old Jun 26, 2008 | 10:12 AM
350zspl's Avatar
350zspl
submerge in water
bubbles will come
Old Jun 26, 2008 | 12:29 PM
a. Tighten the valve stem
b. Fill to 40 PSI
c. Put it in the bathtub.
Old Jun 26, 2008 | 12:35 PM
Motormouth's Avatar
Motormouth
could be a bent or cracked rim. any vibration when driving?
Old Jun 26, 2008 | 12:47 PM
Spork's Avatar
Spork
Submerge it in water or spray soapy water like mentioned earlier. This route is easier, as you don't have to remove the wheel, but you must move the car forward/backward to get the full tire sprayed.
Old Jun 26, 2008 | 02:12 PM
tractng's Avatar
tractng
b. Fill to 40 PSI
Can I tighten from the outside? I am not sure.
Thanks,
Tony
Old Jun 26, 2008 | 03:11 PM
DavesZ#3's Avatar
DavesZ#3
Yes, the TPMS stem has a nut on the outside that tightens. Be careful, the seal is provided by an O-ring on the inside. Tighten it too much and you could cut or damage the O-ring making the leak worse.
Old Jun 26, 2008 | 03:17 PM
aDDandrew's Avatar
aDDandrew
I had the same problem, had the dealer check it out while doing my oil change and they patched it up for free.
Old Jun 26, 2008 | 04:44 PM
Thanks,
Tony
Yes. I meant the plunger and spring assembly inside the valve stem. The one that allows air in when the plunger is depressed, and seals the valve when released.
Old Jun 26, 2008 | 08:58 PM
tractng's Avatar
tractng
Hopefully autozone/pep boys sell the tools.
Tony
loudtoyz
Apr 6, 2023 04:52 AM
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
