how do i jack my car up?
Old Jul 2, 2008 | 08:06 PM
ntwillie1's Avatar
ntwillie1
Default how do i jack my car up?
So i got a new set of rims today and decided to install them. When i went under the car to see where the jack points are i didn't see any. So i just picked a spot that looked strong enough and used that. After I installed the first wheel and lowered the car, i noticed that the piece of metal that it pushed up on was bent. Although no one will ever see it, it does bother me quite a bit. I have a 2005. Is it like this for everyone, meaning, its not clear where you should be jacking the car up from? Thanks.
Old Jul 2, 2008 | 08:08 PM
xdrius's Avatar
xdrius
ZL33PR
check your owner's manual.
i believe there are some diagrams as to where these points are.
Old Jul 2, 2008 | 08:14 PM
surfcity40's Avatar
surfcity40
you could also type "jack points" into "search" but you might be dissuaded by the search function being hidden by an ad. Fear not...someone will redirect you....(give me a second)
Here's every thread imaginable.
https://my350z.com/forum/search.php?searchid=6637463
Old Jul 2, 2008 | 08:24 PM
ntwillie1's Avatar
ntwillie1
I checked, couldn't find it. So i just went with where i thought they should go.
Old Jul 2, 2008 | 08:53 PM
Chebosto's Avatar
Chebosto
umm.. yea.. if you dont know how to change a tire.. perhaps car modding isnt the thing for you (?)
Old Jul 2, 2008 | 09:35 PM
Musto's Avatar
Musto
i would bet 10,000 dollars that at some point in your life you didnt know how to change a tire eaither...
Old Jul 2, 2008 | 09:38 PM
Spanky7829's Avatar
Spanky7829
dam u guys are rough on a simple question.
I thought that was the whole point of a forum. To find out information and share information
Old Jul 2, 2008 | 09:44 PM
Accordaleer's Avatar
Accordaleer
Uh that search result was horrible, dont flame him for not searching. Did you even look at what you linked? Only saw his threat...
Old Jul 2, 2008 | 09:52 PM
surfcity40's Avatar
surfcity40
Thank you for that defense. This is a car forum. We're here to help each other.
Proud of that post....(cept for the "eaither thing...that was a bit wtf).
Old Jul 2, 2008 | 09:56 PM
JETPILOT's Avatar
JETPILOT
There are 2 jack points for the car. One under the engine, and the other is the rear differential housing. There are a few other safe places where the sub frames meet the unibody, but that's for later Danielson! Don't forget to use safety stands. Locations in photo.
Jack Points
Old Jul 2, 2008 | 10:00 PM
vnarang's Avatar
vnarang
Old Jul 2, 2008 | 10:17 PM
surfcity40's Avatar
surfcity40
OP...jet linked you to a non-existent place but i was trying to help. Well I kinda cared.
Old Jul 2, 2008 | 10:19 PM
surfcity40's Avatar
surfcity40
Jack Points
laughed at the Danielson reference.
Old Jul 2, 2008 | 10:43 PM
xdrius's Avatar
xdrius
ZL33PR
Here's the diagram... hope this helps!
Old Jul 3, 2008 | 02:18 AM
Calvin@CRG's Avatar
Calvin@CRG
Temporary Disablement - Billing
the owners manual should have the points but i mean when worse comes to worse the best is under the motor for the front and the rear diff housing for the rear
Old Jul 3, 2008 | 02:26 AM
Z04's Avatar
Z04
true, but when it comes to basic car knowledge, some things should not be asked.
and OP, yes the jack points are in the owner's manual. it is in the "in case of emergency" section
Old Jul 3, 2008 | 01:08 PM
Chebosto's Avatar
Chebosto
Sure.. the interwebs is great if you want to find out specifics about a product like intakes, or turbos, etc or reader opinions... but come on. how to change a tire is one of the most fundamental car skills a driver should know, probably second only to "how to turn the car on."
I'm sorry if the OP can't read the owner's manual instructions, or look at the side of the stock accordion jack to read the sticker on how to operate the device.
as far as the bent in uniframe, nothing you can really do about other than go to the body shop and get it repaired by having it pulled back..
Old Jul 3, 2008 | 01:17 PM
black06z's Avatar
black06z
You might need to keep a separate jack in the car. The oem's are pretty flimsy.
Old Jul 3, 2008 | 03:03 PM
ntwillie1's Avatar
ntwillie1
I've changed many tires before. What I said was that the jack points on my z weren't clearly marked. If you have nothing useful to say then don't say anything at all.
Old Jul 3, 2008 | 03:07 PM
ntwillie1's Avatar
ntwillie1
Thats exactly where I raised it on, and it still got bent. ugly. And thanks for posting this.
