Will these Axis Pentas fit on an '05Z
Old Jul 10, 2008 | 09:35 AM
phandango's Avatar
phandango
Default Will these Axis Pentas fit on an '05Z
My apologies in advanced for the newbie question but I just got the 350Z 3 days ago
I found a pretty good deal on some wheels and wanted to know if they would fit:
Axis Reverb SET 18x8.5 - 5x114.3 15mm offset.
There's no refund so I wanted to be absolutely sure before I made the commitment. Also, is it difficult to transfer the TPSM to the new wheels?
Thanks!
Old Jul 10, 2008 | 12:21 PM
Gag83's Avatar
Gag83
ALSO. watch out when buying axis wheels...
https://my350z.com/forum/wheels-and-tires/189219-cracked-axis-hiro-s-pics.html
Old Jul 10, 2008 | 03:51 PM
Spike100's Avatar
Spike100
The outer edge of your wheel will be 21mm (0.8") farther outside the stock rims. That should be OK and actually look pretty good.
8.5 is not a very wide rim, so you are limited on the tire's width to a 245 or 255. 275 will be too wide.
The bolt pattern is correct.
It's usually no problem moving your sensors to different wheels, but I have no experience with the wheels you mention. Maybe someone else could help on this issue.
--Spike
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
